89 F250 460 fuel filter - Ford Truck Enthusiasts Forums
Old 05-16-2011, 09:12 PM
capn_r capn_r is offline
capn_r is starting off with a positive reputation.
I could use some help. I just got this truck, 1989 F250 4x4, 460, ZF five speed, dual fuel tanks and seem to have some fuel issues. First, the rear tank pump doesn't appear to function (I ran the front tank out, switched and the full rear one stayed full and I was dead in the water) I pulled the fuel lines on the selector valve with the the 6 ports on it that went to the rear tank and drained some really skunky fuel that I put in the front tank to get to a gas station and it started running poorly soon after. I figured it couldn't hurt to change a fuel filter but I can't find one on the truck. The supply line from the front of the selector valve goes to the high pressure pump and a line from it goes to the fuel rail by the distributor and the return leaves the rail by the pressure regulator and heads back to the selector valve. What am I missing? The diagrams I have looked at and component locators seem to place the filter right ahead of the high pressure pump but there is just a line there and nothing appears altered (funky splices,etc) I have done some searching on this forum but haven't found what I'm looking for. Thanks in advance, Abe
Old 05-16-2011, 10:23 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Should be on the inside of the frame rail. Have you crawled under and looked, its prolly in a very lame spot to get to.
Old 05-16-2011, 10:27 PM
I have the truck on a lift and have followed the line from the high pressure pump to the rail. No filter there although everything indicates it should be there.
Old 05-17-2011, 03:53 PM
Update on progress (?) I wasn't getting fuel from the rear tank and I drained the nasty crap out of it. Since I don't appear to have a filter anywhere to be found I pulled the bottom off of the selector valve (the part that says "do not remove cup" on it) to see if it accidentally had a filter in it like some of the earlier / other models had and found nothing but a small o-ring in the bottom of the cup. I then hooked everything back together and put one of Harbor Freights finest pressure gauges on the schrader port on the fuel rail and lit it off. The highest pressure I saw was around 35 psig and it would drop to 15 or so and run worse then pick back up to the 35 or so and run fairly decent. Does anyone have part numbers for fittings to splice the hoses from the rear tank to the one's that supply and return from the engine? I can get by without the rear tank and just want to eliminate variables with the selector valve by taking it out of the loop. Do I have a high pressure pump failing or did I introduce an air leak? Thanks for any recommendations.
Old 05-17-2011, 05:48 PM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
You can get the fuel line fitting repair kits for the fuel lines at NAPA, the kits run between $10-15.
Old 05-17-2011, 07:27 PM
Thanks redmondjp, is that the kind where you cut the plastic hoses and clamp splicers in? I think my high pressure pump just died, you hear a pump for a couple of seconds when you turn the key on, it won't start and it holds about 10 psig. Wouldn't that mean there is power to the pumps but only the low pressure one in the tank is working? I do believe I'm going to do a barbecue juice (propane) swap a little sooner than I had planned. I have most all of the components to do the swap and I believe my ignition will work good for the bbq juice and I don't seem to have any ignition issues (fingers crossed) I don't have known good spares for pumps and selector valves and I don't want to invest in new stuff that would not be used in the fuel change so I guess it is time for the swap.
Old 05-17-2011, 07:38 PM
Edgethis's Avatar
Well make sure you take pics and keep us informed of the BBQ swap.
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
1990 E350 460EFI runs then stalls vacuumbed 1987 - 1996 F150 & Larger F-Series Trucks 6 07-16-2014 05:24 PM
Fuel Gauge Open Circuit Diagnostics Help Franken-Truck Electrical Systems/Wiring 2 12-18-2011 07:20 PM
Fuel tank selector valve - how to test. Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-05-2011 02:20 PM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 08:07 PM
Tags
1987, 250, 460, 89, f250, feul, filter, filters, ford, fuel, fuelfilter, line, located, oring, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
