Gotta get into rear brakes TOMORROW
Well, they are definitely stuck on there. I backed off the adjusters, sprayed some PB around and beat it up good with a dead blow hammer, no luck yet. I'll get them, just sprayed more PB on there, and let them sit till after a little long dinner. Back at in a while. I did rotors, pads on the front last year, 5k ago or so is all.
Sounds like not an expensive repair more than likely, kind I like.
Well, it's been a long while since I did drums (my car is all disc), but I need to do mine. I know it's prolly silly easy, but I love following good directions to maximize my efficiency doing the work. Avoiding gotcha's and the like. Anyone have a good write-up? Also, I'd love to hear some recommendations for good shoes. I am leery of the low'reilleys offerings. I'll pay more for kwality...
IMO a deadblow just won't cut it.
You need a big iron hammer to shock the rust loose.
Whale away, you won't hurt it, and if you do then it was scrap before you got to it.
Put garden hose or something over the studs and beat at the drum between the studs, probably froze to the hub.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I was trying to attach a diagram that maybe helps you. but the internet doesnt allowed.
BTW also remember that there are a primary (shorter) and secondary (larger) shoe assembly and they are in front an in the back accordingly IRRC.
Grab a 3lb hand sledge and start wailing. Nothing like a BFH to get those stuck drums loose. In fact, I broke, that's right BROKE IN TWO, the rotors on the wife's Windstar last night trying to remove them so they could be replaced. Never done that before, but as soon as they cracked, I was able to pull them off by hand. Actually separated the hub section from the rotor.
Just be careful around the lug studs.
Put garden hose or something over the studs and beat at the drum between the studs, Ijprobably froze to the hub.
yea deadblow went out the window as soon as I got back from lunch. Block of wood and little sledge and i popped both off. Got new drums, pads, hardware. Got pics of old crap I'll put up later, its bad. Back outside. Jumped on dads compuer to fill you in.
Oh, yeah, ALL MADE IN THE USA PARTS!!!! Napa, 230 bucks for all.
Well, here is the carnage and a couple pics of the new parts. If you haven't checked your rear brakes in a while, do it. Don't let them get like this! I can't believe I did..
Look at the burn marks on this, nothing left, passenger side rear
Here's a crappy pic of the drum, you can see the deeper groove in the middle
Here is the front of the worst side (pass. side)
Couple pics of new pads and drum
All in all not a bad job. Did it this afternoon, taking an hour and a half to go get parts out of the middle of it. Much better brake pedal now. Didn't think it was bad before, but now its great. Many thanks to all, especially Ian (pglebbia), he gave me his number to call if I needed help.
Oh yeah, gotta mention again, ALL PARTS MADE IN THE USA!!!!!!! All four boxes were marked.
#28
#29
I believe everything was napa brand. I was just happy it didn't say made in china.
Now I noticed I've got a small oil leak in the valley somewhere, running down. Thought I replaced all the orings up there already for oil, not fuel yet though. I'm sure its oil though. Gotta dig in I guess.
