runs better with o2 sensor off?
on
1994 f150 300/6 5 speed
for the last couple months to a year my truck has been slightly sluggish at random times and sometimes would miss horribly on cold start or warm start but then go back to normal, but ive just driven it and not worried about it.
BUT, today i went to pick up my gf and out of no where, it sounded like and exhaust leak and started running amazing. It would actually get up and go and finally for the first time it felt like ALL my power was there, but i knew it couldnt just be an exhaust leak. So, when i got it home, i looked unerneith and the o2 sensor had unscrewed itself from the exhaust and was hangin there, still connected.
Whats with that?? Its running extremely well now with the o2 sensor off but still connected?? Can someone explain this??
Thanks in advance
Thanks in advance
How old is the O2 sensor? More than likely it was giving a false reading to the EEC, and now that it's out of the system the EEC is running in open loop. If I was in that situation, I'd replace the O2 sensor with a new one, clear the memory by disconnecting the battery for awhile, and be on my way.
on
Okay, so i just remembered that it always came loose and i would always have to tighten it due to the PO crossing the threads. I took it off, fixed the the threads, cleaned it and put it back on with some lock tight. Its now running great and the check engine light doesn't come on.
Could the fact that it was loose cause the truck to misfire and all that previously stated?
Thanks for the replies guys!
on
I drove it around yesterday for around 20 min to make sure that it still runs good when warmed up, and it does. So ill just let it be unless it starts acting up again.
Loving the fact that i have all my power back! I forgot how peppy these 300/6 were!
Thanks for all the help guys!
Thats always been my logic
