Double Din Install - Ford Truck Enthusiasts Forums
Double Din Install
Old 05-16-2011, 11:42 AM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
Double Din Install
First off I would like to apologize for the poor pictures. When I set out to do this, I was taking pictures like a mad man. After I finished and was eating lunch, my phone's sd card went currupt and earsed everything on it pictures included. This is the best I can do until I take another dash apart.
First start by removing the factory head unit. You can buy the removal keys or just cut and bend a coat hanger. Either way they work just fine, and unplug the harness and antenna. Then remove your head light switch. (small screwdriver into the little space on the bottom, push screwdriver down while pulling switch out) It will pop right out when done right, don't force it.
Pull dash free from the main dash, I always start from the headlight switch around the top and then back to the switch. They are just clips that hold it in place. Remember it's made of plastic not steel, even steady pressure, don't yank on it.
Now unplug 4X4 switch, airbag on/off harness (standard or extended cab guys, crew cab guys it is there just in a dummy spot in the dash you still need to unplug it) and finally the power port outlet.
Now your dash is free. Take it over to a workbench or table with the new head unit. Test fit the unit into the hole to see where you ill have to trim. I did mine by setting the radio in from the front. On the picture below, I have drawn arrows in red to show where you will need to sand or file. * note: every radio is different, measure twice cut once!
I wound up having to remove the upper and lower lips completely to get my Pioneer AVH-3200BT to fit.
Once the radio would fit in the dash hole, I attached the Metra 95-5818 mounting kit to the new head unit. The radio would fit into the hole and slide almost all the way in, however it was stopping about 1/4" shy of locking into place. That is when I noticed the side stops of the mounting kit were too wide.
I used file to remove some material from the sides of the tabs. It is highlighted in pink where I filed. Remember, you only have on shot with this kit, don't take too much off. If I recall I took 1/16" off each side.
Now reattach the mounting kit to the radio and go for on last fit. It should look something like this when done.
Once it is locked into the dash you will hear it click and turn it over and look for the locks to be set on the mounting brackets. Should look like this from behind.
Now hook up the wire harness, plug in the antenna, back up camera and what ever else you bought with it start the re assembly. I recommend a test run of the radio before everything gets put back together.
Once your dash is back in and radio verified to be working, we'll dress up the last bit of it.
Try each of the trim ring to see which one fits the best. For me it was the one with the longer legs on it. I cut the legs off flush with the trim ring. The cut line is illustrated by the yellow lines in the second picture in this post. Now to attach it to the head unit I used 3M automotive trim tape. It is double side and works great. I only put it on the two thick sides of the trim ring then trimmed the excess tape with a razor blade. Remove the red cover on the tape line up the trim ring and press it into place. Your radio is now installed and looks good.
Good Luck and let me know if you have any questions. I will update this post when I get better pictures of the dash pieces.
Old 05-16-2011, 12:23 PM
ju015dd's Avatar
ju015dd ju015dd is offline
ju015dd is starting off with a positive reputation.
very nice, thanks!!
Old 05-16-2011, 10:17 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Great writeup. Thanks for sharing.
Old 05-16-2011, 10:30 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Thanks Mike!! Mine should be here Friday!! Can't wait!
Old 05-17-2011, 07:21 AM
locknload223's Avatar
locknload223 locknload223 is offline
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
Nice write up Mike, that's on my short list.
Old 05-17-2011, 11:06 PM
baja2000 baja2000 is offline
baja2000 is starting off with a positive reputation.
Great Writeup Mike !!!
I am going to attempt to install the Pioneer AVIC-Z130BT in my 99 F-350
and would like to know witch wiring adapter you used .
Thanks Bill
Old 05-20-2011, 09:09 AM
What did you use for a camera? Also, does yours have rear AUX and USB inputs? I want to do this soon, looking at the AVH-P4300DV.
Old 05-20-2011, 09:38 AM
rustydailey rustydailey is offline
rustydailey is starting off with a positive reputation.
For the wiring adapter I just used one I got at a local stereo store. If you can find one at the parts store or walmart they all work.
Old 05-20-2011, 11:42 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Good work, reps sent!
I mounted mine in the dash and the panel fits to it - not quite as clean, but easier to take dash apart...
Old 05-26-2011, 12:59 PM
I installed my Pioneer AVIC-Z130BT in my 99 F-350 and thanks to the great write-up and photo's by Mike , it went very smooth.
"Thanks again Mike"
There is some damsge too the dash from the thift of the stock radio.
Bill
Old 05-26-2011, 02:15 PM
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
LOL I opened the box for my clarion and then took my truck to a shop... I wimped out.
But i have a friend that owns an auto stereo shop and he installed it for me for about $50.
Plus I had him custom install a c.b into my cubby hole... (After I had already tried by using a swaz-all ooops.)
Old 05-26-2011, 02:45 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
I put my Kenwood DDX516 in over this past weekend. Went super easy thanks to this write-up & pics!! Thanks again!!
Old 05-26-2011, 11:31 PM
kjf-250's Avatar
kjf-250 kjf-250 is offline
kjf-250 is starting off with a positive reputation.
Could you do this without removing the dash? I am looking at getting a Pioneer DVD player but it seems you could just sand it down it place, then connect all the wires before locking it in place. Maybe there is something I am missing?
Old 05-27-2011, 03:45 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Quote:
Theoretically, yes you could. But its much easier to take the dash off. My first time it took me about 15 mins to get off, now I can do it in a matter of seconds.
Also note for ANYONE INSTALLING AN AFTERMARKET RADIO:
When you pull out the factory radio there will be 2 bolts on the top holding the dash trim on. Take those out and leave them out, or that dash trim and radio will be stuck there forever.
Old 05-27-2011, 03:48 AM
A/Ox4's Avatar
9 ECHO 1
Thanks Bill
Only the 4x00 series has the rear AUX and USB. I just installed my 4200DVD and I love it!
Multifunction switch write up strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 18 02-14-2017 09:53 PM
hardcore wheeling pictures KubotaOrange76 Offroad & 4x4 26 12-21-2016 05:10 PM
"rare"?? dirvers side adjustable mirror. danger-ranger93 1973 - 1979 F-100 & Larger F-Series Trucks 15 11-11-2015 02:21 AM
The rebuild of my SD! strokin'_tatsch 1999 - 2003 7.3L Power Stroke Diesel 256 04-03-2015 09:57 AM
Shock replacement......only me.... F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 5 08-23-2013 06:38 AM
Tags
2000, 2003, 99, din, double, excurion, excursion, f250, f350, ford, head, install, radio, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
