Double Din Install - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Double Din Install
  #31
Old 06-11-2011, 03:43 PM
ju015dd's Avatar
ju015dd ju015dd is offline
ju015dd is starting off with a positive reputation.
well I don't know what I am doing wrong or is wrong with my set up. I have it just as you stated above. I have 86 and 87 grounded, and the blue and green like you stated........... always something.......
  #32
Old 06-12-2011, 06:05 PM
ju015dd's Avatar
got it all figured out finally. Thanks guys!
  #33
Old 06-12-2011, 08:40 PM
SLUF681's Avatar
SLUF681 SLUF681 is offline
SLUF681 is gaining momentum as a positive member of FTE.SLUF681 is gaining momentum as a positive member of FTE.
Does anybody have any experience with Jensen radios? I'm looking at a VM9224 for my truck. I'm not sure if I can say that I found it at Crutchfield or not, so I won't say. Anyway, it comes with a rearview camera and all the mounting hardware for $300. Any ideas?
  #34
Old 07-09-2011, 07:40 AM
phoneprincess phoneprincess is offline
phoneprincess is starting off with a positive reputation.
I am looking for a radio double DIN with aux and xm. I have had no xm for the last week and no Glen Beck or Dr Laura has been driving crazy. Dont judge me people. LMAO.
  #35
Old 02-14-2012, 07:11 PM
StillCrawlin StillCrawlin is offline
StillCrawlin is starting off with a positive reputation.
Great write up!!! I bought the Sony XAV-62BT And it came with the kit. I opened it up took out the factory radio. and Stopped. Couldn't believe that the whole Double din is held by two plastic looking cards that clip on the dash faceplate???? But this post answered all ?'s!!!! Thanks again!!!!!
  #36
Old 02-14-2012, 07:24 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
You are quite welcome! That's what this forum is all about! Welcome to the Brotherhood too!!!!
  #37
Old 12-22-2012, 06:33 PM
anasazi anasazi is offline
anasazi is starting off with a positive reputation.
Just what I needed to know to begin this project. The photos are great
and mostly tell the steps to get a double din in that dash.
However, what I don't see is how you actually mounted the radio in the
dash. Is it mounted to the removable dash nacelle and placed back in
the opening with it mounted? Or is the dash nacelle reinstalled after
making the wider opening and then the radio somehow pushed in from
the outside (like the factory unit does)?
Also, that big metal tab/horn sticking out from the pipe that was used
by the factory radio white plastic think that slipped over the tab, did you
cut that out or remove it in any way?
I am installing a Jensen V9424 which comes with a metal ring/box that
the radio slips into and several black surrounds to trim out with. I'm not
sure if I'll use the metal box, but maybe install that from behind the dash
and insert the radio, did you do anything like that?
Thanks for the hints at this job!
  #38
Old 12-23-2012, 01:14 AM
cutlass's Avatar
cutlass cutlass is offline
cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.cutlass has a good reputation on FTE.
I don't have your answers, but am interested in seeing what the answers to each of your questions are since this will be a project I take on very soon in my truck.
Drake
  #39
Old 12-23-2012, 09:08 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
My radio is mounted behind the dash and the dash piece fits over it - not like the OE mounting. I'll see if I can get a pic tomorow...
  #40
Old 12-23-2012, 11:32 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
It wedges in there so tight that I didn't use the metal frame or any mounting hardware at all. I did install something in the back of the unit to prevent it from falling in too deep, but I can't remember what I used.
  #41
Old 12-24-2012, 04:39 PM
Got it installed one way or the other....
As Tugly says, the fit is fairly tight. So after grinding the plastic dash
nacelle open to its limit for the vertical fit (horz. is ok) I reinstalled the
dash. Next I found that metal horn thing sticking out from the the metal
pipe that is the console support was too high up and the radio hit it and
would not slide in all the way.
I used an 8" crescent wrench to bend the leading edge of the metal
horn down about 1/4" on the front only. This provided a ramp sort of
which the new radio hits and then goes up over. This makes a farily
tight fit and I don't think I'll do anything else to secure it in the hole.
I then was able to pull it back out a bit and snap the plastic nacelle
ring that came with the radio on and this closed up the ugly openings
all the way around as I see in your installation. You might try that to.
You should have gotten 2 different nacelle rings to use with the radio.
That's it and I"m done. I guess if I get on it with that big diesel 7.3L
a bit hard the radio might come popping out of the hole!!! I doubt that
would happen as it's no dragster.
Thanks for all the advice guys!
  #42
Old 03-20-2014, 09:50 AM
jmurray101 jmurray101 is offline
jmurray101 is starting off with a positive reputation.
I know this is an older thread, but when I installed my Double Din head unit if I push it all the way in, the motorized face gets bound up and wont move. Do I need to take more from the upper and lower lips, or am I going to have to find a spacer to set the unit farther out from the dash.
Thanks for info
  #43
Old 03-20-2014, 11:05 AM
Tugly's Avatar
There is usually a threaded hole in the back of any stereo. I installed a bolt of the proper length and padded it to prevent wear/cutting of anything behind the dash.
  #44
Old 03-20-2014, 11:12 AM
There isn't any rubbing on the back, the motorized face wont tilt allowing access to the DVD slot if I push the unit all the way into the dash opening. I think the head unit needs more clearance up and down to tilt the screen out I just don't know If this is common problem or I need to trim more.
  #45
Old 03-20-2014, 11:34 AM
baja2000 baja2000 is offline
baja2000 is starting off with a positive reputation.
Quote:
Thanks for info
If you look at post #23 you will see the head unit I installed in my f-350 I also just install the same unit in my 2000 Excursion . The instal kit I used has side plastic brackets that hold it in. You need too trim the dash levying only about 1/16" inch all the way way around and most important the two screws on the top off the opening have to be be remove or the head unit not open and close properly Bill
Leak? Water pump or T-stat housing? F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 7 01-15-2014 09:29 AM
BigRed's Engine Pull GTG F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 105 04-25-2013 05:57 PM
OH!!! Spark plug broke off in the motor!!! 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 27 03-19-2012 08:55 PM
ICP Replacement F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 5 04-13-2011 08:08 PM
Intercooler pipe painted F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 7 02-27-2011 09:22 PM
Tags
2000, 2003, 99, din, double, excurion, excursion, f250, f350, ford, head, install, radio, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
