2007 Ford F150 xlt supercab 4X4 - Ford Truck Enthusiasts Forums
Old 05-15-2011, 07:00 PM
tajenkin tajenkin is offline
tajenkin is starting off with a positive reputation.
I have a 07 F 150 that i had the front brake pads, rotors, and calipers replaced, a day ago (reputible shop) and now every so often the brakes get extremly hot to the point of smoking, i had the system also flushed and refilled at the time of replacment, after it sits for a while and cools off it runs okay and then when i drive it again it is like the brakes are just grinding away, with out any pressure on the pedal, to the extent that is shakes at a reasonable speed and slows the car down when i let off the gas more thatn normal. it feel like the calipers are not releasing the brake
on occasion what could the problem be? it does not do this every time i drive the car, i took it back to the shope and it did not seize up all the way there, so they are thinking im crazy... any help would be appriciated.
Old 05-15-2011, 10:17 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Might want to go down to the 2004-2008 F150 forum. My guesses would be pads over shimmed or not seated properly, calibers not releasing properly, warped rotors, or anything in between.
Old 05-16-2011, 05:12 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Moved to correct forum.
Old 05-24-2011, 07:35 AM
scothill scothill is offline
scothill is starting off with a positive reputation.
drivers side window button 2007 xlt
The window will go down when pushing down the button, but when going up you have to hold the button midways and sometimes play with the button to make it close all the way! Any suggestions how to fix problem?
Thanks,
Scott
Old 05-24-2011, 08:14 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Quote:
Thanks,
Scott
Welcome to FTE!
Here is a thread from this week that is likely to shed a little light on your situation:
http://www.ford-trucks.com/forums/10...h-upgrade.html
Enjoy!
Old 05-24-2011, 09:51 AM
Quote:
Originally Posted by MCDavis View Post
Welcome to FTE!
Enjoy!
Thanks a lot MC DAVIS!
Old 04-14-2014, 11:22 AM
5.4 spark plugs
Going to install new spark plugs and tryed to remove the front one on the passenger side, it was tight, moved over to the front one on the drivers side it was also tight. My son is at home right(12:00) now spraying some PB spray on the the plugs. Going to try it when I get home this evening which will be about 4:30pm. Anyone with some suggestions would be greatly appreciated.
Old 04-14-2014, 11:23 AM
2007 5.4 f150 5.4
Brake caliper sticking 88 e150 annaleigh 1968-2013 Full Size Vans 15 11-11-2015 10:34 PM
Help with bad brakes (long post) Steven Day 1997 - 2003 F150 4 08-18-2015 07:58 PM
Brake Question for 1993 Ranger marks500 Ranger & B-Series 2 02-07-2015 05:37 PM
Brake caliper locking up Fordf25091 1999 - 2003 7.3L Power Stroke Diesel 20 09-08-2014 06:38 AM
Left front caliper; weak pressure? simulatedjim 1999 to 2016 Super Duty 8 08-09-2014 07:51 PM
Tags
1999, 2003, 2007, 4x4, cab, covers, duty, f150, ford, mpg, super, supercab, truck, xl, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
