IWE question - Ford Truck Enthusiasts Forums
IWE question
Old 05-15-2011, 06:06 PM
mustangski mustangski is offline
mustangski is starting off with a positive reputation.
IWE question
Good evening,
I have a 2006 F150 4X4 with the 5.4, about a week ago I started hearing a squealing sound coming from the front passenger side. I thought it was a bearing so I pulled it apart yesterday. I pulled off the wheel end and found some metal shavings in the grease and it does make some squealing sounds when I spin it in my hands. I already ordered the Timken IWE, should I have to order anything else? I am going to pull the half shaft out and clean all the metal shavings out of the grease prior to re-installing it. Any thoughts on this? Also, what keeps moisture out of the internal hub gearing as the IWE had no gasket or silicone on it. Both of these were already replaced under warranty about 30,000 miles ago. I appreciate any advice.
Jeff
Just about ready to drive truck in river, IWE ISSUE STILL. ChrisCarter 2004 - 2008 F150 8 02-17-2012 09:52 PM
Binding in 4 wheel drive Techfree 2004 - 2008 F150 6 12-14-2010 07:28 AM
MAJOR problems...IWE or worse??? PLEASE HELP!!! 970mmj 1997-2006 Expedition & Navigator 21 12-21-2009 09:49 PM
Grinding 4x4 Problems IWE woody24 2004 - 2008 F150 3 10-05-2008 08:22 AM
Warn IWE 96f150 2004 - 2008 F150 2 03-21-2007 06:08 AM
Tags
f150, ford, iwe, replacement, silicone, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
