Modular V10 (6.8l)
Power loss at WOT, after 30 seconds
Old 05-17-2011, 12:55 PM
one 427Cobra's Avatar
one 427Cobra
one 427Cobra is offline
Originally Posted by dkf
I take it you were driving 81 a good bit of the way through PA? Sounds like you may have grossed more than you thought you did.
More like 91.
And my excuse was, no really officer it started going faster and faster all by itself there was nothing I could do. That cop had no sense of humour whatsoever.
Old 05-17-2011, 01:08 PM
dkf's Avatar
dkf
dkf is offline
I referring to interstate 81.
Old 05-17-2011, 02:03 PM
one 427Cobra
Yes I was on interstate 81, doing 91 downhill, uphill 25.
Old 05-17-2011, 04:02 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
I definitely agree fuel pressure is first thing to check. Not easy or cheap to safely monitor real time, but it is a very likely culprit.
If OK, I start to wonder about the stock 2000 fuel map resulting in excessively lean ratios and some combustion chamber overheating, leading to preignition and the knock sensor pulling timing out.... Or something along those lines. Dyno tests have shown some odd behavior at WOT.
I would have a conversation with Mike (5 Star).
Old 05-17-2011, 04:14 PM
dkf's Avatar
dkf
dkf is offline
I was thinking along those lines also. The cat temps could have been very high also. Not having the trailer on the back reduced engine load and must have lowered the temps enough. Maybe the engine even went into limp mode for a short duration. You know as well as I do that year runs stoich almost all the time unless it overheats.
Do you know the actual GCW of your entire rig? (trailer included) If not it would be a good idea to get it on the scales. I have traveled the same section of I81 dozens of times over the years. The grades are long but they are not that steep. I have enough power to be running over 90mph at the top of the same hills, granted I'm only at 11,500-12,000 lb GCW. Thats with a PI 2V V10 with the 4speed auto in an F-250 pulling a boat so there is not as much wind resistance. I suspect your GCW is higher than you think.
Old 05-17-2011, 09:07 PM
SuperSlimTony's Avatar
SuperSlimTony
SuperSlimTony is offline
Does a 2000 F53 v10 have a check valve?? Where???
I has been knocking a bite more lately???
What about a clogged converter?? What about removing the converter?? Short straight pipe??
I'm still waiting for my adapter!!!!
T
Old 05-18-2011, 10:26 AM
one 427Cobra
T
It’s in the return line from the carbon canister (driver’s side approximately 2’ from the gas tank)
Old 05-19-2011, 12:27 PM
one 427Cobra
Originally Posted by Krewat
What are your valve covers made out of? Plastic=2-valve, aluminum=3-valve.
Valve covers are plastic.
Old 05-19-2011, 12:30 PM
one 427Cobra
Originally Posted by bill11012
what does it weigh in at?
28’ motor home @ 14500 lbs, civic @ 2300 lbs, trailer @ 1800 lbs.
According to the owner’ manual max towing capacity is 5000lbs.
Old 05-19-2011, 01:34 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
To add for extra things being carried in the car and RV, lets just call that 18,000 lbs.
This is mine with about that same weight going from 0-70.
I have 30 less HP due to mine being the very early V10, but you have more wind resistance.
YouTube - ‪V10 0-70 18,000 lbs‬‏
Old 05-19-2011, 02:19 PM
one 427Cobra
[quote=bill11012;10362029]To add for extra things being carried in the car and RV, lets just call that 18,000 lbs.
Ok! You re & re your engine and I’ll do mine and it’s an even trade.
From what I have seen of this video there is definitely something wrong with my engine, maybe I’ll take that video with me to the ford dealer and tell them that’s what I want mine to do Lol.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Have you ever been to Pennsylvania if yes, does it pull Ok on those long hills?
Old 05-19-2011, 03:09 PM
bill11012's Avatar
bill11012
Yea, if you can't do than you have an issue. I would take it to Ford since its under warrenty.
  #28
Old 05-23-2011, 05:39 PM
SuperSlimTony
Update:
Hooked up fuel pressure gauge, 30 PSI @idle, 20 PSI @WOT, then when i loose power it actually picks up to 24 PSI, and still no power???
  #29
Old 05-23-2011, 07:08 PM
Super08's Avatar
Super08
Super08 is offline
You should have way more than that. My old 4.6 had around 60 stock. After I supercharged it and put in double pumps I had close to 100 or better. I forget exactly but either way yours is way too low.
  #30
Old 05-23-2011, 09:12 PM
SuperSlimTony
What should the fuel pressure be?? 2000 F53 2v V10??
Quick Reply: Power loss at WOT, after 30 seconds
