I am trying to drop my track bar so I can take it to the vice to replace the bushing on the frame end of the bar. However I can not get the bar to drop off the ball joint on the axle. What am I doing wrong??
Old thread but just curious if you know the size of the nut to remove track bar. I want to make sure I have a large enough wrench and the nut looks big.
like drey04 said its 30mm socket, and make sure you get a six point socket not a 12point like i did the first time. Its very painful when that crap 12point slips off! And when you reinstall use a 1/2 breaker bar with at least a three foot piece of pipe over the handle and tighten the bolts till you cant no more, then they should be tight enough
Will replacing my trackbar fix my tire wear issues? Alignmen and balance is good. Shocks are new, balljoints are new. I get feathering on both tires and outside wear on passenger tire.
