Glove Box question
Old 05-15-2011, 12:08 PM
dwrestle's Avatar
dwrestle
dwrestle is offline
Glove Box question
My glove box is broken, and flops open all the time. I was wondering if you can buy a new door for it from somewhere?
Old 05-15-2011, 12:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I doubt a new door is what you need....
Open the door and look at the latching mechanism. When you squeeze the sides, do the two silver things get sucked in OK? If not, replace that latching mechanism; if so, adjust the other half, the half that's screwed to the top to which the first half latches to.
I really doubt you need new anything........
Old 05-15-2011, 01:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
misadjusted, I agree with CTUBUTIS...
Old 05-15-2011, 02:09 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
If you do need parts, LMC have the doors & latches.
Old 05-15-2011, 02:46 PM
dwrestle's Avatar
dwrestle
dwrestle is offline
I took a picture of it, but I can't figure out how to post it. Anyway I think the whole latch on the door itself is pretty much gone. It doesn't look like it was ripped off or anything it looks clean on both sides of the door. On the back side of the door that would latch to the inside of the glove box is a black plastic thing that fits inside the black plastic thing in the glove box, but it is hollow and it should probably have little colapsable wing things to latch with. Also the front of the door is void of any buttons of any kind. So I am guessing I probably need a new latch. The thing on the inside of the glove box looks like it is worn but in good shape.
Old 05-15-2011, 03:34 PM
81-F-150-Explorer
Most of those parts are in the wrecking yards.
sounds like the buttons on the sides of the latch are stuck. Try WD40
Do you have the courtesy lamp group, and/or security group?
Old 05-15-2011, 04:25 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
This should help you with pictures.
https://www.ford-trucks.com/forums/forum77/
In short:
You can upload them into your Gallery or Album here or any free hosting service (I use imageshack.us) then add the necessary coding to make the pictures show up inline in your posts.
There is a Test forum where you can play:
Testing..... - Ford Truck Enthusiasts Forums
Old 05-15-2011, 06:11 PM
dwrestle's Avatar
dwrestle
dwrestle is offline
Here is a pic of the front of the glove box. The wire is the PO's latching system LOL. I took a couple more pics but they somehow didn't save to my phone. You should be able to tell by this pic what is going on.
Ford Truck Enthusiasts Forums - dwrestle's Album: My 83 F-150 - Picture
Old 05-15-2011, 06:43 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Here are some pictures of my non-locking glove box latch. I picked 2 locking latches (one with a key, one without) at a junkyard last year for a couple of dollars for both. I took them apart one at a time and cleaned them, put them back together, and re-keyed them to fit my truck key. I was going to use all the best parts and make one good one. But, as it turned out all the parts were very good. They are very easy to work on, a little spray, a few adjustments (that includes adjusting the catch at the top of the glove box) and they work as good as new. I hope these pictures help.
Old 05-15-2011, 07:13 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Instead of using the Picture URL, use the BB Code stuff below it - copy and paste that into your post and the picture will show up inline.
Old 05-15-2011, 07:47 PM
dwrestle's Avatar
dwrestle
dwrestle is offline
Hope this works.
Can someone tell me what the technical names of the part, and or parts I need to fix the dangling annoyance.
Old 05-16-2011, 08:08 AM
Grubbworm's Avatar
Grubbworm
Hope this works.
It looks like you need to make a trip to your local junkyard to get a new latch. If you look at my pictures you can see that the latch is held in place on the door by a plastic clip. Once you remove the clip, the latch will come right off. Your latch does look like it is missing pieces. I would opt for the junkyard route, since it is much cheaper and usually you can find one that is just as good as a new one. As far as technical names, I would just call it the "Glove Box Door Latch". I hope this helps.
Old 05-16-2011, 01:15 PM
81-F-150-Explorer
Ah, the latch has split apart into two pieces. The whole front half is missing.
Yep new latch is what you need.
Old 05-17-2011, 02:25 AM
Ken Blythen
Does anyone know if the 80 - 86 glovebox liners that LMC sells are plastic, or heavy cardboard (or both)?
Old 05-17-2011, 12:52 PM
81-F-150-Explorer
Gloveboxes from mid 1985 are plastic... so look in the wrecking yards would be prudent.
Rich G
04-30-2017 08:04 AM
TheBestNeverRest
2015 - 2020 F150
09-03-2016 11:44 AM
93truck
1999 to 2016 Super Duty
08-06-2011 06:08 PM
phoneman91
03-21-2005 05:59 AM
frosty64
03-20-2005 01:49 PM
Quick Reply: Glove Box question
