Transmission fluid change - Ford Truck Enthusiasts Forums
Old 05-15-2011, 11:35 AM
Fordfreek!'s Avatar
Fordfreek! Fordfreek! is offline
Fordfreek! is starting off with a positive reputation.
Well I just bought a '79 F-150 and I want to change the tranny fluid/filter, but the current fluid doesn't look too healthy. It doesn't really smell burnt, it has a real strong fluid smell, and the color isn't exactly cherry. it still has a little of the red color in it, but it's more of a goldish red, almost transparent red. I don't want to drop the pan and change the fluid/filter and the tranny go out on me a day later. What do you guys think? I know there's always a risk, especially with an older transmission, but as of now it seems to shift smooth I would just like to have new fluid and a new filter.
This is about as good as a pic as I can take of it......
Old 05-15-2011, 12:21 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
The thoughts or "urban myth" of NOT changing the fluid comes from transmissions that are run for like 100,000 miles without ever having things done and then the fluid and filter are changed and the tranny goes to pot.
Bascially the estra grit in the fluid helps with the lack of grit on the bands/ clutches.
I wouldn't think twice about changing the fluid. Definately makes for piece of mind knowing the fluid is fresh and clean.
You're pic isn't super clear, but the fluid looks tired, but not toasty. Might have gotten overheated a time or two, but nothing too alarming.
Some will say to use Dexron/ Mercon my $.02 is to only use Type F.
Josh
Old 05-15-2011, 12:25 PM
pat67shorty's Avatar
pat67shorty pat67shorty is offline
pat67shorty is gaining momentum as a positive member of FTE.pat67shorty is gaining momentum as a positive member of FTE.
Use type F. It's less "slippery" than dex/merc and will firm up the shifts, extending the life of the clutches and band.
Old 05-15-2011, 12:48 PM
Fordfreek!'s Avatar
That was a crappy cell phone pic. I only ask because it has happened (once to me and once to my brother) twice before (78 Fairmont wagon and '94 Escort) I worry because I do not know when/if the fluid was ever changed. Better pic coming. Thanks for the responses guys, really does make me feel a little better about doing it, and I'm right there with you with the Type "F".
O.K, here's another crappy pic, but you can see the color a little better I think anyway....
Old 05-28-2011, 02:00 PM
Fordfreek!'s Avatar
So I am finally going to get around to doing this today. I wanted to drive the truck a few miles to see how it was shifting before I dropped the pan. I'm still nervous, but at least the fluid doesn't have a burnt smell to it, that eases my mind a little bit. BTW, this is my first dentside, and I gotta say, these are some damn tough trucks.
Old 05-28-2011, 02:06 PM
Fordfreek!'s Avatar
And for the hell of it, here is a pic of the beast.......
Old 05-28-2011, 06:11 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Either way you'll end up changing the fluid now or when she blows from not doing it.
97 Aerostar: trans fluid capacity wanna know? aerohiwaystar Aerostar 10 08-24-2015 11:17 PM
7.3 tranny fluid change Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 11 03-04-2015 01:51 PM
Now I am stumped, all suggestions welcome Lazarus88 1987 - 1996 F150 & Larger F-Series Trucks 5 06-16-2014 09:57 AM
transmission fluid and filter change 62star Explorer, Sport Trac, Mountaineer & Aviator 1 07-05-2012 09:40 PM
Transmission fluid change... silly34 6.0L Power Stroke Diesel 8 01-15-2010 12:41 PM
Tags
1973, 1987, 2005, change, check, color, expedition, explorer, f100, fluid, ford, myth, ranger, transmission, trucks, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
