Digital vs Analog gauges
Like Clay said, the Performax gauges are more expensive cause you have to buy the ESP at first. The cool thing is though, thats a one time cost and you can add up to 17 gauges to it. EV2 gauges each have their own sender (which is why they cost more compared to a Performax gauge) and need wires run from the senders to each gauge. The Performax series uses only 3 wires that run from the ESP into the cab. All your gauges go on those 3 wires, so its easier to install, especially if you plan on adding more gauges down the road.
Another question would be regarding the degree of difficulty with installation. Having read installation instructions for electrical monitors, it sounds pretty easy, just unplugging a few clamps and plugging in the monitor. I am aware that I will have to drill for the EGT and there should be an spot for the tranny temp, but what about boost, oil temp, fuel pressure, etc? I have plenty of experience with the wiring aspect and I think that I can handle drilling and tapping the exhaust. What about the rest? ...
I am not sure about electric oil temp since I don't have that one myself. There is a factory sensor already installed so you might be able to piggy back off that signal for the Performax system but the EV2 may need to have it's own sending unit that you'll have to find a home for. Clay (Riffraff) can help you with those details.
I don't think there is an option for mechanical EGT so you are probably out of luck if you want one of those. Even if someone does make one, you probably don't want it because that is a lot of heat to conduct into the cab and it will cause more problems then it's worth. My '55 Bel Air has a mechanical engine temp gauges and I hate it. If it wasn't for the fact that it's original, I would have changed it to electric by now.
Mechanical boost is pretty easy to install. You just run a small plastic tube into your cab and connect up to the back of the gauge. Sort of like an air pressure gauge...
Mechanical Trans/Engine oil temp and Fuel pressure require that you run the lines all the way up to the gauge which most of us don't like doing because of the possibility of a leak and getting fluid all over the inside of our trucks.
In my experience, mechanical gauges are far more difficult to install compared to electric gauges. (boost being the only exception so far...)
In fact, I wouldn't be surprised to learn that the reason electrical gauges were created was to ease installation.
The Performax and EV2 are the same gauge. The difference is the ESP box and it is probably your best choice for ease of installation but it also is a little bit more $. The hardest thing you have to do is find a home for the ESP module. Robin did a very clean installation on his truck that was quite impressive. If I had to do it all over again, I would have sprung the extra coin for the Performax just so I can add some gauges later (which I am already thinking about doing.....again).
Like I mentioned earlier...I have ISSPRO EV2 in my XLT and Autometer Phantoms in my wife's Lariat. The EV2 are way better in my opinion...especially at night. They are very easy to read and that by itself has a ton of value to me.
I hope some of this info helps.
Glad we could help Gary, and look forward to talking to you.
carguy3j
08-28-2015 10:39 AM
