Rear Cab Mounts
Rear Cab Mounts
I've noticed rear of my cab is about 1" lower then the front, (looking a long the top of the running board to the bottom of the cab).
Can the wear of the bushings cause this must of a drop. I didn't noticed any issue with the mount to the floor. No rust at that point. pretty clean. If I run my two fingers wide between the cab and bed you can also see about the same inch difference.
I think it has also been my problem with the a alignment with my hood and cab. It looks like If I were to tilt the cab forward that gap would close.
Need some advice in this area.
Thanks
Ed
Thanks
Ed
The pinchweld at the lower corner is probably the strongest place back there. That's the hangy-down flange under the cab corner with the spot welds connecting the outer skin with the inner structure, if you don't know what a pinchweld is. (and if you do, please pardon the remedial body shop lesson)
Mid Fifty's adjustable arm?
Are they just for R-n-R & go or would anyone reccomend them to use
for a "frame-off" type truck rebuild?...
dmack91
06-29-2013 11:12 AM
fyrtrks
04-24-2002 08:51 PM
Charles-65F350
Paint & Bodywork
02-08-2002 05:37 PM
