oil temp sensor on 2002 7.3 - Ford Truck Enthusiasts Forums
Old 05-14-2011, 10:07 PM
kenny778 kenny778 is offline
kenny778 is starting off with a positive reputation.
i am having problems finding someone to help me locate my engine oil temp and sure could use some help
Old 05-14-2011, 10:47 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
The sensor is located on the back of the HPOP reservoir, driver's side.
Old 05-15-2011, 08:40 AM
okay thanks for giving that info . i guess i should have ask about my issue. i changed eingines fromm 2002 w/auto trans. to one from 2001 w/ manual tranny and now i have no fast idle when engine cold and am trying to find problem. this is why i am looking for help.
Old 05-15-2011, 09:07 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 05-15-2011, 09:18 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Quote:
Did you swap out sensors from old motor to new? One other thing to look at is the air intake seņor mounted in the air box, did you leave it unplugged?
Also the engine coolant temp sensor on those two engines is most likey different. That shouldn't effect the high idle, but may cause other issues.
Old 05-16-2011, 08:34 AM
i did swap temp sensors because the plugs were different, also changed complete engine wiring harness. i did plug in cold air sensor but so far still no fast idle when cold. it does start when cold but no hiss or fast idle. when i unplug what i think is cold oil sensor it will not even idle unless i step on pedal a ways.
F350 Oil temp, Trans temp Gauges kabur66 6.7L Power Stroke Diesel 7 09-12-2011 12:06 PM
water temp sensor and oil temp sensor JMAN21 1999 to 2016 Super Duty 5 07-20-2011 01:41 PM
oil temp Bill2 6.0L Power Stroke Diesel 18 07-05-2011 04:24 PM
engine oil temp light tneyman 1999 - 2003 7.3L Power Stroke Diesel 12 12-15-2010 09:29 AM
Oil temp vs coolant temp teppler 6.0L Power Stroke Diesel 14 02-10-2010 12:52 PM
Tags
1997, 2000, 2002, 54l, 73, engine, f150, f250, ford, gauge, installation, location, oil, sensor, temp, temperature, tempeture
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
