Lost turbo pressure today??
I have had this issue severl times My truck has 8,000 miles and is in the shop for the last 10 days they have ordered an EGR cooler we will test the truck tomorrow to see if it the problem or if Ford is just swapping parts. My local dealer is not very good when it comes to "FIXING" anything. I will repost when I know more.
Mine has been clanging away since new. It is under very light load at low rpm's that the banging occurs and often, but not always, the boost pressure jumps around. It is in the dealership for the third time and Ford admits they are aware of the problem but have yet to say what the fix is. This problem has caused my check engine light to come on three times now. The error code the dealer is getting is stating a low boost condition.
Has this issue been resolved? I ask because it seems to have happened to me. I was driving the truck last week, cruising at about 50km/H as I went to press the pedal a little harder to downshift the truck to drop down a gear, the truck felt very sluggish and I looked at my boost gauge and noticed I had no boost pressure at all. I made the whole trip with no lost pressure. The weird part was once arrived to my destination and shut the truck off, I came back an hour later started driving and it's like nothing ever happened.
As the problem reoccured? Let me know, I might be able to help. Send me a PM if you require my assistance!
Thanks,
Mathieu
Anyone have a fix for this issue yet
been scanning the threads trying to find a solution.
I have a 11 6.7 that has been randomly loosing boost . Power the truck down and back on all good.
took the truck in ( extended warranty) initially dealer replaced wastegate seleniod, problem came back. Replaced wastegate actuator. Problem came back.
Turbo was leaking oil so dealer replaced my turbo. Problem came back within 2 days of new turbo.
There was a TSB for a PCM flash due to wastegate issues. That was done as well.
dealer and I are both at our wits end. No codes ever show up. Always seems to happen when I am either too far away from dealer or the dealer is closed.
sorry for digging up old thread. Love this truck and don't want to give it up but this random turbo issue is really making look.
Was there ever a remedy to this issue?
The reason I'm asking is that it happened to me today, started moving after a red light and the truck seemed very sluggish. Then it downshifted going up a small hill that it never downshifts before. I looked, and noticed the turbo gauge at 0, no boost. I pulled over, turned it off, then restarted to still no boost, and the truck is very under-powered. I looked over the area, and do not notice any leaks, also no leaks underneath. I hooked up my OBD reader, and no codes.
Thanks for your help.
EDIT 8/5 = Decided to start a new thread since this was an old one ( https://www.ford-trucks.com/forums/1...l#post17376822 ).
hi been having trouble with my 2011 6.7 with lower turbo presher coming and going. Runs normal psi most of the time but then randomly will get stuck as low as 13psi.
Do you have a fix for this issue? My fathers 2012 f-350 has the same symptoms. The turbo will work fine until the ignition is switched off, then (upon restart), the turbo will quit until the ignition is cycled again, at which point it works fine. He is contemplating getting rid of the truck (100% stock w/ 130,000kms), or deleting the DPF/EGR and doing a flush to clean the turbo. Any help is greatly appreciated.
Mathieu,
tgreening
48
04-18-2016 02:37 PM
dieselsubmariner
15
03-28-2016 11:42 AM
