1990 f150 wipers not working
Old 05-14-2011, 02:22 PM
syntax_error's Avatar
syntax_error
syntax_error is offline
Ok im having a problem the wipers and sprayers are not working on my f150. Been google searching and can only find stuff related to the govener. They dont work on any selection on the switch and i dont see a fuse or a relay for them in the kick panel. Any one have any ideas.
Old 05-14-2011, 02:52 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Duct Tape Racing is offline
There is a relay box undernith the hood, check the wiper relay
Old 05-14-2011, 02:55 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Nealcrenshaw is offline
Check for voltage at the motor with the switch on check for a good ground as well.
Old 05-14-2011, 02:58 PM
Duct Tape Racing
heres a diagram for ya. thats the one in the cab. Wipers/ washers is in the #2 position. I would say its a fuse because its not likely that they both shat out at the exact same time.
Uploaded with ImageShack.us
Old 05-14-2011, 03:05 PM
syntax_error
i was sure my number 2 position said not used but i will go out and check
Old 05-14-2011, 03:07 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Well....My wiper fluid sprayers seem to have a mind of their own...Sometimes they'll work, sometimes they don't.....
Swapped the fluid resevoir pump unit out, and no dice....But since my low beams side of the headlight/wiper stalk doesn't work, I am assuming its related....Seems logical to me....
Just about ready to say F it and wire the pump up on a toggle switch...
Old 05-14-2011, 03:09 PM
syntax_error
ok i checked number 2 is definatly not used and there are no relay banks under the hood.
Probably should have stated that this truck is a 90 xlt lariat 4x4 if that makes any difference
Old 05-14-2011, 03:12 PM
SideWinder4.9l
Doesn't matter.....It'll have 2 fuse banks....One in the dash, and one under the hood....The under hood one will be on the drivers' side, behind the air filter...Between the filter and the firewall...you can't miss it...It'll have the Ford logo on it....About a 5" x 8" black box...
Old 05-14-2011, 03:19 PM
syntax_error
i just went to double check again and there is not another bank under the hood there is just a strip for the trailer towing, ecc power, and fuel pump. with direct connectors for each no relays.
Old 05-14-2011, 03:21 PM
SideWinder4.9l
Hmmmmm.....Sounds like its in the stalk...How many miles on the truck? Mine only has 171k...And the stalk is all fugged up...
Old 05-14-2011, 04:50 PM
Duct Tape Racing
Wiring sucks.
i know that doesnt help but i just wanted to say that. lol
Old 05-14-2011, 04:52 PM
SideWinder4.9l
Originally Posted by Duct Tape Racing
Wiring sucks.
Great words of wisdom right there...
Old 09-28-2012, 04:33 PM
Dustpan95's Avatar
Dustpan95
Dustpan95 is offline
Im having the same problem with my 1994 F150. its not the fuses and its the the other fuses in the engine compartment. So I traced the wiring in my diagram and it lead me to the pulse board/governor/relay. Whatever you wanna call it. turns out, mine is fried. Im notorious for using southern engineering with electrical things to make stuff happen. I cant do that with this. It just wont work. That specific part is $120 brand new. So Im just gonna go to a junk yard and buy one. Hope this helped. Btw, I had a 1998 F250 and it didnt have a distributer box in the engne compartment. but my 94 does. So yours might not.
phoneman91
62
03-13-2024 09:16 PM
tm01027
09-11-2017 02:57 PM
OlBrownTruck
04-27-2017 04:02 PM
dickiefrank
08-06-2016 03:08 PM
mattd860
13
05-30-2009 06:21 AM
Quick Reply: 1990 f150 wipers not working
