73 f100 rag joint repair
Old 05-14-2011, 02:18 PM
rustyranger390's Avatar
rustyranger390
rustyranger390 is offline
New guy here, been researching this like crazy but can't find excatly what I need for my year and model.
Gonna try to install a rag joint repair kit on 1973 F100, manual steering. All I can afford right now.
Would I still need to remove the entire coupling from the gearbox and intermediate shaft to install just the new rubber and bolts?
Would I still need to grind off the old studs?
Thanks for any help, this forum has been a great help already to me!
Old 05-15-2011, 07:15 AM
rdweathers's Avatar
rdweathers
rdweathers is offline
I bought my repair joint from Advance Auto Parts, under $10.00. You need to remove joint completly from steering gear box and steering wheel shaft. Unbolt rag joint from both, i unbolted steering gear box from frame - 3 bolts, will need to remove brake line support bracket to get to one of the steering box bolts,leave gear box pitman arm attached to linkage and gear box, no need to remove this, gear box will pull away from steering shaft and rag joint will fall out. You will need to grind off top of rivets to remove rag on coupler and install new. Mine had a metal plate sandwich between joint and steering shaft in order to make the ground connection for horn to work, be sure to put this back in the same way it came out or you will be doing this procedure twice like i did. Good Luck.
Old 05-15-2011, 09:12 AM
rustyranger390
Hey thanks rdw...so no need to move steering column at all, simply move gear box.
When you say unbolt from both ,that includes pinch bolt at gearbox too, right?
I think my brother and I can get her done.
The safety pins are doing the steering right now!
Old 05-15-2011, 05:08 PM
rustyranger390
Well, we got'er done...
Advance did not have the kit but only had the entire joint for $32.00. So I did'nt have any rivet grinding to do.
Did unbolt the gearbox like rdw suggested, but we moved the column too. When it was all said and done we had a big gap at the steering wheel, so he loosened the clamp near the firewall and we were able to move the column back up closer to the wheel so the horn and signal cams worked.
Not sure how tight the bolts to the flange should be but he tightened them up pretty snug where the rubber mashed pretty substantial.
Any input on how tight they should be would be appreciated.
Thanks guys, it's been a long afternoon
Old 05-15-2011, 07:25 PM
rustyranger390
Lil' simpler
How tight should those flange bolts be?
Thanks guys!
Old 10-10-2011, 05:51 AM
75PKUP's Avatar
75PKUP
75PKUP is offline
I just replaced my rag joint on Saturday, it only took about 45 minutes total. I loosened the old one, removed the bolts on the steering box, lifted it up and the old joint fell out...put it back the same way.
The only "problem" I had was once it was all bolted back together, my steering wheel wasn't straight. Since I have a Grant wheel though, I simply unbolted it inside and straightened it. It steers like a new vehicle!
Oh and by the way, those bolts should be good and tights, I didn't tighten them till the rubber "squished"
Old 01-30-2015, 12:10 PM
teh_ca73's Avatar
teh_ca73
teh_ca73 is offline
Attached is a pic of my troubled '73 F100 4X4 Henry Blue. Even though it has a newer Red head steering box, the steering (manual) is next to impossible. Is there a rag link that can be replaced here? For the life of me, I see no flexible rubber disc.
All help would be greatly appreciated.
Old 02-01-2015, 01:57 PM
maytea's Avatar
maytea
maytea is offline
Re
I have same setup on my 79 f250
No rag joint.
You can buy a rebuild kit that gives you a new spring and bushings for the universal joint.
Got mine at advance auto...
Old 02-01-2015, 01:59 PM
maytea's Avatar
maytea
maytea is offline
Taking anouther look at where the shaft goes through the firewall it looks like you are missing, the plastic cap that holds the lower bearing
Old 02-02-2015, 03:46 PM
teh_ca73's Avatar
teh_ca73
teh_ca73 is offline
Steering shaft universal repair kit?
No rag joint.be NAPA
Thanks for the info. Any idea what the kit is called? No Advance Auto here - maybe NAPA can step up. Thanks again!
Old 02-02-2015, 03:49 PM
teh_ca73's Avatar
teh_ca73
teh_ca73 is offline
Missing steering bits..
Really, missing steering bits? Can anyone point me to an exploded diagram or part numbers of my missing pieces. Thanks again for your input.
Old 02-02-2015, 05:39 PM
maytea's Avatar
maytea
maytea is offline
Original plastic is hard to find. I got mine from jy.
Look here for aftermarket
http://www.ebay.com/itm/All-Metal-Lower-Steering-Column-Bearing-76-79-Early-Ford-Bronco-Truck-F150-/261752029141?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1979%7CMake%3AFord&hash=item3cf1a2ffd5&vxp=mtr
Old 02-02-2015, 05:45 PM
maytea's Avatar
maytea
maytea is offline
Old 02-03-2015, 08:15 PM
teh_ca73's Avatar
teh_ca73
teh_ca73 is offline
Missing Steering bits 73 F100 4X4 Manual steering...
All Metal Lower Steering Column Bearing 76 79 Early Ford Bronco Truck F150 | eBay
I'm afraid that ebay piece looks like a 2WD piece. Do we have an exploded schematic of a 73 4X4 (manual steering, 4 speed) on the site?
Old 02-03-2015, 08:20 PM
maytea's Avatar
maytea
maytea is offline
Not sure where you see this lower bearing housing for steering shaft is only for 2WD. I have a 4WD and it is same. This is all I have eer seen for any 2wd or 4wd.
jdworley
10-04-2016 03:19 PM
FordStolz68
08-27-2016 02:05 AM
Drpomaville
07-10-2016 09:54 AM
vidaliaman
05-13-2016 11:43 AM
tomlauten
03-13-2013 10:28 AM
Quick Reply: 73 f100 rag joint repair
