My Project.. The 6-door 4x4.
Really the FTE facebook page? Why is it not legal in canada? I got a buch of crap back in the 90's for going up there in a peterbilt with a spread axle trailer. They let me in but told me to never come back with that trailer again.
Advice
I took a couple of pretty big chances building this. The rolled truck was out of Dallas, and the flooded dually came out of Houston from hurricane Katrina and I live in near Wichita, Kansas. So I bought them both without seeing them in person. Sketchy... If you buy a 4x4 that's hit in the front make sure if the front axle gets pushed back that its not on the pumpkin side. If it is there is a chance the driveline bottoms out and either breaks the transmission or transfer case off of the motor now your talking about droppin some cash to fix it. But I got both trucks and everything turned out good. The burned truck I got to see so that was all good. The other issue I ran into was from what I understand 99-01 PSD trucks are wired the same. Well I put a 1999 cab on a 2002 frame. So I had to completely rewire the truck from headlights to tail lights. including how the computers come through the firewall and the dash. I had to completely gut both trucks to sheet metal and cut the firewall out of the grey 2002 and put it in the hole I cut in the 1999. As I am sure you can imagine it was a nightmare. I had a full time job, single guy that had his daughters 1/2 the time and a full time college student. So just that took almost 3 months. I tried to find the thread I wrote about how to build the truck but had no luck.
im on my 2nd 6 door build.
my last was a 87 F350 IDI,
this time is a 01 F350 short bed DRW.
I ran the main truck before it blew a HG, so all of my wiring is still intact, but I suspect I will need to do some tweaking on the chassis harness.(swapped a 01 F250 on a 02 F350 chassis)
both trucks I used were cali trucks, so they were super nice, and since registration is a mo fo here, I got both for dirt cheap.
I just got the roof done, now time for the floor.
but I used a full crew cab rear half.
these extended trucks are awesome, arnt they!
https://www.ford-trucks.com/forums/1...4wd-build.html
#28
#30
clintonvillian
153
02-12-2024 09:47 AM
JustinP
74
04-15-2017 08:40 AM
76f350spercamprspeal
97
04-03-2016 10:16 PM
