ZF S5-42 vs 47
ZF S5-42 vs 47
Help me remember what all the differences are between the two. I know the 47 is supposed to hold more power and have a stouter input shaft but what else. I've seen a good info sheet on it before but cannot locate it now and I have one on the 42. I'm interested most in durability and the difference in gear ratios.
The reason behind this all is because I've found a 47 with low miles for a good price. I'm trying to decide if it would be worth buying and putting in and then selling my 42 to break even.
the 47 has a different throwout flange for it, you can replace it without pulling the case apart.
I believe there were some bearing and structural differences with it, but I'm not 100% positive on that.
The main difference between the 2 is the throwout collar/flange.
Either way, the 47 is better, so buy it and re-build it.
powerstroke
This guy has a 2-wheel drive 5-speed in Connersville. Can you just remove the tailshaft on the 2-wheel drive ZF?
The 47 is rated at 470 ft lb tq
Diesel zf 5 42
1st Gear:4.14
2nd Gear:2.37
3rd Gear:1.42
4th Gear:1.00
5th Gear:0.77
Rev Gear:3.79
Diesel zf 5 47
1st gear:5.08
2nd Gear:2.60
3rd Gear:1.53
4th Gear:1.00
5th Gear:0.77
Rev Gear:4.66
I gotta agree with that. When I had 4.10s 2nd was no biggie all day long but after switching to 3.55s I can start in 2nd easy when the clutch is cold but for some reason after it warms up it's not such a good idea. And reverse is pretty dang quick too. Looks like id like the 47 much better.
No, I think they made one transmission. For the two-wheel drive units, they added a tailshaft. For the 4x4 units, they left it off.
You split off the tailshaft end and then the two-wheel drive transmission should mate right up to your transfer case.
Someone who knows these transmissions better than I should be able to confirm (or deny) this.
I spoke with Dan at Midwest Transmission about the 42/47 at length.
A trans guy that works on them everyday says to forget the 42 and go for a 47.
I have a 42 here for a swap but gave up on the swap after talking with him till I can find a 47.
I don't recall specifics other than something like "There are a lot of good internal upgrades for the power the PSD puts out in the 47."
Good enough for me to want one.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
