It depends on the quality of job you want done... Also if you do any prep work, that will help bring down the cost... Are you looking for a quickie macco job or what?
I had my Camaro done a while back for just under 500 bucks, all white. I did most of the prep work. It was through Macco.
You could probably get it done for somewhere between 1000-2000 for just a cheap, but "fair" quality paint job. Again it depends on how much you want them to do. If you do the prep work, 1000 bucks for some good paint sprayed on. You want them to do it, 2000 would probably get you a fairly good paint job.
I just got a qoute a couple day's ago from a good shop if i do the prep work and them spraying a two stage paint Dupont paint $780.00 them doing everything 1800.00 for just the outside and 2200.00 for outside, door jambs, under hood, between the cab - bed and tailgate jambs was 3100.00
