options
options
Hi all, I am new to the forum here.
I have a '99 F250 V10 I bought used about 2 years ago. Yesterday, the spark plug from the cylinder at the very back of the drivers side engine bank came out. It blew out. It apparently had been repaired before as the plug has an oversize insert around the threads.
Obviously the plug blowing out can be repaired but, can the failed repair be repaired or do while I have to buy another head to fix it?
What are my options? The motor seemed to run fine. It rattles somewhat but it ran OK. Has around 115K on it.
Has anyone swapped in the 7.5L gas engine into one of these trucks? Would the transmission from the V10 bolt up to the older 7.5L? Has anyone ever replaced the V10 with another V10? How do you remove the engine from one of these?
Thanks!
Thanks!
Welcome! I would lean toward fixing the blown plug, but it does seem odd that it has already been repaired once. You just may need to gamble if you decide to fix the plug, that it was done incorrectly the first time, and you will not have another blown plug once you fix it.As far as swapping in a 460, I would think it would be doable, as long as you get all the computer and wiring from the donor truck, preferrable with the trans, and even then I think it would be a pretty costly swap.
