How to manually turn the engine over - Ford Truck Enthusiasts Forums
Old 05-14-2011, 08:36 AM
Kendrick Kendrick is offline
Kendrick is starting off with a positive reputation.
It was mentioned before about trying to advance my engine a little so my starter might kick in properly. any information on how to do that would be appriciated.
Old 05-14-2011, 09:13 AM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Put a socket on the crank pulley (either use and extension or a deep well to get past the pulley). Put a ratchet or breaker bar on the socket. Turn it.
Whats wrong with the starter?
Old 05-14-2011, 09:15 AM
you can hear it spin but it doesnt turn the engine over. I had removed it to get it tested and when I put it back on it just made noise. some one said it might be on a bad spot.
Old 05-14-2011, 10:31 AM
advancing it a tad did the trick. Now i just have to get the nose of the IP to stop leaking and the purge will begin.
Old 05-14-2011, 11:32 AM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
You can try giving the starter a wack with a soft faced hammer. Another thing to try is on the big nut on the cable put the wrench on and act like you are going to loosen it but don't your goal is to turn the seloniod slightly, Because the issue you are having can be caused by the seloniod turning when you tighten the cable down on it and binding things, turn the seloniod back the other way (whitch can be done by trying to turn the nut on the cable) and you should be good to go.
Old 05-14-2011, 11:38 AM
arizhnt arizhnt is offline
arizhnt is starting off with a positive reputation.
I assume the starter tested good? Look for a broken tooth/teeth on the ring gear/flexplate.
Old 05-14-2011, 03:14 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
WOW! Why didnt I think of that haha....think I could advance my engine like that so it wouldnt hit the bad spot on my ring gear
Old 05-14-2011, 03:15 PM
Aune163rd's Avatar
Then again i was just doing it by pushing the truck and letting the clutch out for a foot or so....
Fuel Dilution of Engine Oil jackfordsd350 2017 Super Duty 16 03-09-2017 01:50 PM
How much does turbo 7.3idi engine weighs? BahamasIDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-05-2013 10:44 PM
Internal or external Balance? JB78f150 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 06-01-2012 01:20 AM
engine slamin79 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-14-2010 12:22 PM
Engine Size FFBruce 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-15-2003 11:03 AM
Tags
351w, 73, 73l, bar, diesel, engine, ford, manual, manually, manualy, powerstroke, size, socket, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
