Michigan Chapter Join Chapter, Leader: Toyman
87 F-150 that stalls when put in gear
Old 03-23-2003, 01:41 PM
diamondray's Avatar
diamondray
diamondray is offline
Unhappy 87 F-150 that stalls when put in gear
without tearing motor completely apart does anyone have a clue on this?
flywheel has teeth missing in only 1 spot.
I have taken tranny off and replaced.
but while tranny is off checked rotation and can only turn motor 3/4 of the way around and it freezes up-turn the other way and same thing. I get to that certain point and can't turn the motor
any further.
motor was running fine (no knocks or pings) thought it was touque converter at first but know it's not now.
any suggestions?
motor is FI 302.
Old 03-23-2003, 02:27 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
Diesel_Dummy _ is offline
timing chain
Old 03-27-2003, 07:19 PM
diamondray's Avatar
diamondray
Timing chain and gears seem to be alright (looking at them anyway) no cracks,dents,or bruises.
Old 04-20-2003, 06:03 AM
golf_wrench's Avatar
golf_wrench
golf_wrench is offline
Sounds to me like you either sucked a valve or broke a rod if the engine will not turn a full revolution.
The title of your post was something about engine stalling when put in gear but then you say it ran fine before.
I guess I must be having a brain fart.
Bill
Old 09-10-2003, 07:36 PM
GolfMech's Avatar
GolfMech
GolfMech is offline
I have to agree With Bill If you can rotate the engine by hand albit partial rotation I think you have a definate obstruction to rotation.....3/4 turn sure sounds like about 270 degrees of rotation...SOmething ugly is blocking the other 90 degrees.Good luck.
Tbelanger
1999 to 2016 Super Duty
04-21-2014 04:35 PM
05truckguy
2004 - 2008 F150
16
02-24-2012 01:07 PM
Prairie Lariat
35
08-24-2009 09:58 AM
spiker86
Bronco II
03-25-2008 02:16 PM
Quick Reply: 87 F-150 that stalls when put in gear
