Leaking Ac refrigerant - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-13-2011, 07:20 PM
Jtanner76 Jtanner76 is offline
Jtanner76 is starting off with a positive reputation.
I tried charging my ac, and found a nice leak dripping down from the bottom of my compressor.. not sure if its a busted line, or a bad o-ring. The problem is the ac compressor is located on bottom side of 5.4 motor.
How difficult is it to remove and service the compressor. i have a 05 EB expy.
Also i 4x4 pretty hard with it, is it easy to damage a line under there?
Old 05-13-2011, 08:49 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
It is not too hard to get to under there. Clean the area of the leak. If you have to, use some brake clean. If it's only a little oil it should be okay until you can get it properly serviced. You need to be careful not to overcharge the system or you could cause yourself bigger problems.
Old 05-14-2011, 10:07 AM
2Fords1Jeep 2Fords1Jeep is offline
2Fords1Jeep is starting off with a positive reputation.
There are EPA laws governing the release of refridgerant into the atmosphere, so I would recommend having your system's charge reclaimed by a pro prior to removing anything. The system will then need to be evacuated to a vacuum prior to recharging the system after the leak is repaired. Unless you have the proper tools, training, and equipment this is not a DIY project.
Old 05-14-2011, 12:32 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
There are 164,480,000,000,000,000,000 (real number, not made up) ounces of air on Earth. He's releasing maybe 30 ounces of refrigerant. That's "0.00000000000000000001823929961089494163424124513 6187%" of the air on Earth that's being 'contaminated'. I'd say hotdog and beans night at the Jones's house does more damage to the environment than him releasing that refrigerant into the air.
Old 05-14-2011, 08:35 PM
Moto Mel's Avatar
Man, that's a lot of air. I wonder how much of it is hot, outside of Washington, that is.
Old 05-14-2011, 08:50 PM
Quote:
It's people like you that caused the problems that were addressed by the Montreal Protocol in 1987. Licensed professionals care and follow guidelines. Educate yourself, because if you are suggesting that it's OK for everyone to release "maybe 30 ounces of refridgerant" you may to use your own math proficiency to estimate those "hotdogs and beans".
Old 05-14-2011, 09:07 PM
Moto Mel's Avatar
Lighten up a little. Much more Halon escapes from a gozillion sources every day and I beleive the greatest cause of Global Warming is just too many people creating too much methane gas. There are times when I think the worst thing that happened to planet Earth was Humans. There are just too damn many of 'em!
Old 05-14-2011, 10:08 PM
Quote:
Some do, some don't. I have educated myself, that's why I can safely say that global warming is a myth, holes in the ozone from aerosol can are a myth, and R-12 or even R-134a released into the atmosphere will not destroy the environment. Most people have no comprehension as to the size of this planet and what it would actually take to really effect it.
Old 05-14-2011, 10:16 PM
Quote:
You think so? Here's a little fact to put the world's population into perspective. Ever been to or at least seen pictures of New York City? Well if you were were to take the state of Texas and develop it with the same density as NYC, you could house the entire population of the world there. Got that? The entire population of the entire planet living working and existing in a space the size of Texas. Walking down the street would be no different than walking through NYC.
Old 05-15-2011, 12:39 AM
Moto Mel's Avatar
With that much crowding the streets would be knee deep in blood until there was a population reduction. People, for the most part, do not want to live quite so close to each other.
Old 05-15-2011, 10:47 AM
As "supporters" and "Postmasters" I would expect, regardless of your own personal opinions regarding ozone depletion, that at least you would not recommend illegal activity.
Old 05-15-2011, 12:33 PM
Yeah, yeah, yeah, I hear the High School in Shelton Connecticut will be looking for a new Principal. It sounds like you'd be perfect for the job.
Connecticut teen garnering support after prom ban - CNN.com
Old 05-24-2011, 11:14 PM
robc2064's Avatar
robc2064 robc2064 is offline
robc2064 is starting off with a positive reputation.
Isn't it an interesting coincidence that R-12 was banned right when Duponts patent expired. But here, we have this new freon with a new patent that will save the universe. Look, up in the sky. It's Dupont Man beating off the competition with a new patent.
Leak in high pressure AC line Glenn54 1987 - 1996 F150 & Larger F-Series Trucks 9 01-03-2017 10:29 PM
What A/C compressors will work? 1988F1504x2 Ford Inline Six, 200, 250, 4.9L / 300 1 12-29-2015 11:19 AM
91 f150 a/c problem.... joelfx4 1987 - 1996 F150 & Larger F-Series Trucks 10 08-12-2010 12:56 AM
ac mount for econoline astumbo Ranchero & 1961 - 1967 Econoline 10 01-21-2008 09:21 AM
ac compressor seized samralh Explorer, Sport Trac, Mountaineer & Aviator 6 03-11-2004 07:04 PM
Tags
2005, 2010, 99, ac, air, conditioning, expedition, f150, ford, freon, leak, loosing, losing, r134a, refrigerant
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
