Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-23-2003, 01:01 PM
lgdb is starting off with a positive reputation.
engine id
Can someone help id my engine? The numbers on the back of the block are D9AE-6015-ED17. Below the ED17 is 9A10.
Thanks for any help......
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-23-2003, 04:33 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
engine id
What the casting numbers tell us is that it's a 79 block (D9= 79) and the 9A10 looks like the date code (79-Jan- 10). Do you have the truck to go with it?-your door tag will have the engine code on it. Is the thermostat/upper rad hose outlet located in the intake manifold or in the block? How many bolts in the valve covers?
  #3 (permalink)
Old 03-23-2003, 06:54 PM
engine id
No we do not have the truck to go with it. The thermostat/upper rad is located in the intake manifold and the valve cover has 6 bolts.
  #4 (permalink)
Old 03-23-2003, 07:00 PM
Mil1ion is starting off with a positive reputation.
engine id
Sounds like a 302 to me.
Oiginally designed for a 79 Large Ford Car.
  #5 (permalink)
Old 03-23-2003, 07:13 PM
Craigwell's Avatar
Craigwell is starting off with a positive reputation.
engine id
Now THAT would be a wicked addition to an already incredible site.. Imagine a casting number decoder on the site, somewhat like the VIN decoder site that exists elsewhere on the web..
too bad i'm only good for ideas, and not programming
__________________
1976 F250 4x4 'HighBoy'
300 Swap, AOD
"Frank"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
