Measuring 351W deck height? - Ford Truck Enthusiasts Forums
Old 05-13-2011, 10:54 AM
Aaron-71's Avatar
Aaron-71 Aaron-71 is offline
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
How exactly is this done?
I've got a 351W from the early 70's (cougar or stang), so it should be a "9.480 deck height, but I want to be sure of the ACTUAL deck height before I try to build a stroker engine.
Wasting money and time isn't exactly something I like doing...
What would I have to do to measure up the deck height?
Old 05-13-2011, 02:16 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
By definition, the deck height is measured from the centerline of the crankshaft to the deck. So you need to rig up something that marks the crank centerline that you can measure against. The makers of your stroker kit should know about your specified deck height, and use the correct height piston.
Old 05-13-2011, 02:22 PM
Aaron-71's Avatar
Quote:
Yeah, I need to make sure of the deck height, otherwise I'll have my pistons 0.023" out the top of my deck haha.
Old 05-13-2011, 11:47 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Since the main journals are 3.000" one could get hold of a chunk of 3 inch cold rolled steel, just long enough to straddle two main journals, with the bearings and caps installed. Then using a depth micrometer the distance from this to the block deck is measured. Add an inch and a half and that is the deck height.
Using a smaller diameter piece of steel would also work but it will be difficult to hold in place and measure to.
Old 05-14-2011, 07:33 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
You could also just reference the block casting number...
Kelly hotrod - Ford Engines Page 2
Old 05-15-2011, 02:19 PM
Aaron-71's Avatar
Thanks man! This will definitely be the easiest way to go!
The casting number on 351's is behind the starter on the lower passenger side of the vehicle, isn't it?
Old 05-15-2011, 03:36 PM
Of course if you use the casting number you have to assume no one machined the deck surface.
Also if you have a casting date around the change over period there might be uncertainty.
Old 05-16-2011, 09:23 AM
Aaron-71's Avatar
What's a change over date?
I'm not fully certain what you mean by this.
Old 05-18-2011, 01:01 AM
The change over date is the date at which Ford switched from producing 351W blocks with 9.480" deck height, to 9.503" deck height.
Ford publications say that 1969-70 engines were machined to the shorter deck height, while 1971-on blocks had the taller height. Both received the same length rods and same (compression) height pistons.
What is the casting number of your cylinder block?
Old 05-18-2011, 10:31 AM
Aaron-71's Avatar
I'll have to get that within the next few days. As of right now, I'm SUPER busy after work and don't have a chance to take a look. I'll definitely get back to you though.
Old 05-18-2011, 10:35 AM
Deck heights
To add to my previous post, the confusion can arise if one has a D0OE cylinder block, for instance. If made early in the year (for a 1970 model vehicle), it should be lower deck height, but if made late in the year for a 1971 model vehicle, then it should have the higher deck height.
It is imagineable that one could even get a high deck C9OE block if some of the castings were still in inventory late in 1970 and then finish machined. It all depends how things were done at the foundry and machining centers.
So the date code on your engine's cylinder block is also very important.
Deck.Height balboni 1987 - 1996 F150 & Larger F-Series Trucks 2 08-17-2015 06:57 PM
351W quench minimum?? lizardman1 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 03-14-2014 02:43 AM
What 460 pistons to use with 10.300 deck height?? bigdan1979f-250 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 05-11-2009 05:05 PM
351w stroker CR doug1222556 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 35 01-28-2008 11:08 AM
New 400 Piston, Need Feed-back TMI 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 67 08-17-2006 01:17 AM
Tags
1987, 351, 351w, 50, 97, block, checking, deck, f150, ford, height, hieght, hight, machining, specs, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
