Cab in bed? Will it fit?
if it's the same bumper i have, it's closer to 5/16" thick. i have a reciver welded to the bottom of my bumper, and use a reese style hitch in it..... i've towed a 6700 lbs dozor, on a 1800 lbs trailer with mine..... no problems.... i'v also had a 4x4 bronco try winching my out by hooking to it.... burnt the winch up, then tried the ram it in reverse method, only to stall the bronco in 4low. and never even moved the bumper....
i think your bumper would be more then strong enough to haul a trailer and a truck cab...
if you have a way to load and unload the cab (tractor, forklift) i'd just put it in the back of your truck.... take some blocking and strap it in good.... i've hauled a cab for our 580 case in the back of my f-100....( about 300 miles)
__________________
1990 f-150 ext. cab, long box, xlt lariat
5.0, a0d, 3.55gears, came from down south
forsale 78 f-100, 302, aod, dual's w/ss glasspacks, 9" w/3:50' (lookin for 4:10's)
custom steel body
