P0708 - 2001 Ford Ranger transmission range sensor questions?
Old 05-12-2011, 10:21 PM
5.0stang's Avatar
5.0stang
5.0stang is offline
I got a code P0708 and my check engine light is on and o/d light flashes on/off constantly.
Do you guys find that it is typically the sensor or the connector? Both?
Also, any write-ups on how to replace the sensor?
Thanks!
Old 05-13-2011, 06:48 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Might be a bad connection, might be the sensor, might be the PCM, or might be the harness.
Start somewhere, like cleaning and reseating the connector, and go from there.
Old 05-18-2011, 03:14 PM
5.0stang's Avatar
5.0stang
5.0stang is offline
Alright, today I replaced the transmission range sensor (neutral safety switch).
The first drive (for about a mile) ran great. The o/d light was not flashing anymore. Then, just going down the highway it all started up again.
"First into second" gear shifts hard, but the other gears are normal.
I also sprayed out the terminals at the range sensor plug.
Any thoughts?
Old 05-20-2011, 09:39 AM
5.0stang's Avatar
5.0stang
5.0stang is offline
Any ideas for those that have went through this?
mitchc
1997-2006 Expedition & Navigator
01-13-2017 10:38 AM
F250Oldie
1999 to 2016 Super Duty
07-15-2016 09:17 PM
nick_ct_203
12-31-2015 03:45 PM
nick_ct_203
20
09-16-2015 03:17 PM
jrhs1959
05-14-2006 07:03 PM
Quick Reply: P0708 - 2001 Ford Ranger transmission range sensor questions?
