5 speed shifter problem - Ford Truck Enthusiasts Forums
Old 05-12-2011, 07:52 PM
bigfoot7180 bigfoot7180 is offline
bigfoot7180 is starting off with a positive reputation.
a friend of mine has a 90 f150 4x4 with a 302 5speed in it.it wont shift gears correctly unless you pull up on the shifter then it does fine.any ideas what it is?
Old 05-13-2011, 10:54 PM
hmmmm no ideas??????????????
Old 05-13-2011, 11:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Worn out shift forks?
Old 05-14-2011, 01:51 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is online now
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
i had a 5speed that dropped a shifter rail and wouldnt shift right
Old 05-14-2011, 09:40 AM
blackjack95 blackjack95 is offline
blackjack95 is starting off with a positive reputation.
the thing is that u shouldnt be able to pull up on it.if its loose u got somethings wrong.under the boot there are 4 alan bolts that hold it in place i think. see if there tight.just a thout
Old 05-14-2011, 07:48 PM
xxshine xxshine is offline
xxshine is starting off with a positive reputation.
If you get the thing fixed, consider going to a Hurst shifter. It has 30 % less throw. Be a careful shopper on the Hurst web site. Different shifter arms are available for the shifter assembly itself.
Old 05-15-2011, 11:37 PM
thanks for the ideas and replies
Old 05-16-2011, 01:03 AM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
A very common problem are the plastic bushings
the shifter pivot ball sits in crack. There are two bushings
If the bushings crack, they cause excessive wear on the pivot
pins which are pressed into the side of the shifter top cover.
Here's a picture of the repair kit. You can purchase one on
Ebay. Search for M5R2 shifter.
No need to pull the transmission. Everything can be installed
after you remove the shifter which is held to the transmission
top cover by 3 torx bolts.
The kit includes the 2 bushing halfs, 2 pivot pins and
sometimes the 3 torx bolts that hold the shifter to
the top cover along with the cover plate.
Here's a link with a diagram that shows the parts.
There is also in the same link a YouTube video that shows how to replace
the bushings. The vehicle in the video doesn't appear to be a F150 but the repair
process is the same as for your vehicle.
http://www.ford-trucks.com/forums/97...tify-part.html
Old 05-16-2011, 02:06 AM
thank youf150xlt
Old 05-16-2011, 08:51 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
x2... I've done this twice on a couple friends 1/2tons and it's an easy 1-2hr fix. If you haven't changed your tranny fluid in a while I'd suggest doing that at the same time. Remember preventative maintence allows less of this later on...
Old 05-16-2011, 11:31 AM
fordmanbrad's Avatar
fordmanbrad fordmanbrad is offline
fordmanbrad is starting off with a positive reputation.
I just put one of those kits in this weekend, and it made an amazing difference. In fact, the old plastic bushings were nowhere to be found when took the cover off. I guess they broke, fell inside and got ground up.
Ebay is the best deal going for that kit.
shifter for 87 5speed fatazz350 Ranger & B-Series 1 05-06-2016 12:06 PM
Hurst Floor Shifter billest 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 10-24-2013 09:28 PM
WTB: ZF 5 speed shifter... custom1106 WTB - Parts & other 1 03-20-2012 01:10 AM
broken shifter mike_rockwell 1987 - 1996 F150 & Larger F-Series Trucks 7 01-15-2010 06:52 PM
Shifter removal question Mercury Bluz 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-29-2008 09:21 PM
Tags
1988, 1996, 96, arm, f150, f250, ford, lever, problem, problems, ranger, shift, shifter, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
