2005 F150 Engine Replacement - Ford Truck Enthusiasts Forums
Old 05-12-2011, 07:37 PM
elogane elogane is offline
elogane is starting off with a positive reputation.
Hi all,
My 2005 F150 has 107,000 miles on it's 5.4 SOHC. It started making loud metal to metal noises, and the check engine light came on.
The dealership is telling me the the Cam Phaser problem is a known issue, and there is a TSB on it. After they inspected the engine, the told me that the total repair costs would be about 3,700.00 (Phasers, timing chain, cam, guides, etc., etc.).
I think that I'd be better off with putting a rebuilt in it, and am waiting for a quote from the dealership.
Does anybody know if Ford will help with the costs associated with either the the repairs or the replacement. It's not only a known issue, but apparently a very common problem.
From what I can find out, a rebuilt 5.4, out the door, runs about 3,000.00, and about 8 hours labour.
Any advice, help, or comments will be greatly appreciated!!
Thanks!
Ed
Old 05-12-2011, 07:48 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Comments only, I have not played with this series engines. All I do is drive mine. Given the repair of a hundred thousand mile engine that has had metal run through it vs a rebuilt that would have a warranty for a bit more money, I would opt for the rebuilt. Hopefully some of the guys that work on these things will offer real world advice. Best luck. BTW, welcome.
Old 05-13-2011, 08:28 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Thread moved to the 2004-2008 F150 forum.
WELCOME to FTE!
I would concur, a rebuilt makes a whole lot more sense, IF there was metal going through the engine. What actually happened? Did a cam stop and you have bent valves/broken pistons?
Old 05-13-2011, 01:31 PM
What I'm "told" is that the timing chain guides are broken, allowing the chain to slap around, which damaged the chain. The cam is scored, and the phasers, Lash Adjusters, and sprockets have to be replaced.
There is more, but you get the idea, also, they said that there may be damage to the main bearings... good grief.
Anyway, of the 3,518.00 price quoted for a repair, 2,020.00 is parts.
This morning, they quoted me a price for the long block replacement. This is a Ford rebuild, out the door, for 4,600.00 in parts, and 2,070.00 in labor. Add in the tax, and the total price is 7,070.20, with a Ford warranty of 3 years, and unlimited mieage.
I could get an angine shipped to the dealership and have them install it foe about 1,000.00 less, but then no Ford warranty.
A lot of money, but then, I plan on keeping the truck for at least 3 years.
Thanks!
Ed
Old 05-13-2011, 02:18 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
I have seen several 5.4s that have had the cams scored and had to be replaced. The good news is if you do this repair you should be replacing all the weak points of these engines (phasers, timing chain guides and tensioners). I would opt for the repair myself as the bottom end of these engines have shown themselves to be very solid but obviously i have not seen yours to know how much metal could have went through it I am just drawing from past experiences
Old 05-13-2011, 08:30 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
If the cam is scored then the head is scored too. The cams ride on machined journals directly on the cylinder head which is softer metal so anything that scored the cam also scored the head. If you plan on keeping the truck I would put a reman in.
Old 05-13-2011, 08:49 PM
I'm a bit worried that I might be being a bit overcharged on the labor to replace the engine. From what I've been told and seen on the internet, that 8 to 10 hours is about right. $ 2,070.00 in labor seems extreme. Any thoughts on that?
Thanks!
Ed
Old 05-13-2011, 08:53 PM
Actually in the chilton book it is 19 hours. They are prob charging 16 plus whatever teardown done to the original engine. That's what I charge.
Old 05-15-2011, 10:49 AM
gcozmo's Avatar
gcozmo gcozmo is offline
gcozmo is starting off with a positive reputation.
How about looking into a used, low milage engine from a salvage yard. Could you pick up one with say 30K or 40K miles and have it installed cheaper.
Old 05-15-2011, 01:43 PM
Thanks GCOZMO, I looked into that option. However with the Cam Phasers a know issue in the 2004 through 2007 5.8's I might just be picking up another set of expensive problems. You would think that with Ford having knowing about the problem for more than 6 years, that they would at least help out folks whose engines fail due to that "known issue".
Old 05-15-2011, 02:58 PM
kawasaki150hp kawasaki150hp is offline
kawasaki150hp is starting off with a positive reputation.
When I read that they were charging you 7K my first thought was wow that's cheap. I just had a new motor put into my truck and got it truck back on Friday. The cost was $10,200 installed. Thankfully I had an extended warranty and it only cost me my $100 deductible.
Old 05-15-2011, 07:44 PM
gcozmo's Avatar
Quote:
But didn't they have a mid year '07 head change that were not supposed to have the plug and phaser problems that we experience? I have read this in some posts because I checked the manufacture date on mine hoping that it was the new design and it wasn't.
Anyhow, it was just a thought but if you can swing the new reman. engine then that would definately be the way to go. GOOD LUCK!! Sounds like you have thought it through.
5.4 3V expert advice needed to replace phasers vs whole rebuild? 66 bronco roadster 1999 to 2016 Super Duty 49 08-12-2016 11:32 AM
Cam phaser help Zach Carter 2004 - 2008 F150 3 03-21-2016 08:21 AM
Trade in or fix 2005 F-150 with 5.4 3v? 1964f-100 2004 - 2008 F150 12 06-20-2015 05:27 PM
Valve job or long block? 80,000 miles bbells2009 2004 - 2008 F150 3 02-27-2015 09:29 PM
2004 F150 3v triton Timing issue after sparkplug break tear down. Please help. dexterslab724 2004 - 2008 F150 3 06-13-2013 04:53 PM
Tags
05, 07, 2005, cost, engine, f150, ford, motor, price, rebuilt, repair, replacement, replacment, transmission, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
