'99 5.4 Misfire - Power Loss - Etc... - Ford Truck Enthusiasts Forums
Old 05-12-2011, 06:48 PM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
ceetwarrior is gaining momentum as a positive member of FTE.
Cool '99 5.4 Misfire - Power Loss - Etc...
Hey guys, my 99 E250 is acting up. No power, very sluggish, rough idle, feel it in steering wheel etc...
First thing I did was change fuel filter. No change.
A week ago I scanned it, and it say P0306 Cylinder 6 Misfire. Also, P0174system too lean. I put new plugs in and cleared the codes out.
I pulled fuel rails and injectors and used a 9V battery, carb cleaner, etc and did the DIY injector cleaning like I always do.
At that time I took off all 8 coils ohmed them. They were all identical results. I jumbled them up and put them in different holes. I put in new motorcraft platinum plugs.
Now a week later (still running like crap) I checked fuel pressure. It's 31psi at idle, 40psi with vaccum disconnected and 40psi under load. I rescanned it and its coming up with P0308 Cylinder 8 Misfire.
By process-of-elimination does it appear that I have a bad coil? That the #6 coil got put in #8 hole and it's just simply bad? Any other ideas on where else to check?
Any help would be great. Thank you!
Old 05-15-2011, 12:54 PM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is online now
enriched&beyound is starting off with a positive reputation.
Appears that you're on the right track.
If you could get a known good coil and place it on # 8 and see if it clears up or continue to move #8 to another location and see if symptoms continues to follow.
only suggestions that springs to mind, is to clean the throttle body...AIC...& MAF.. and possibly the EGR. Also make sure you don't have a vacuum leak, double check the PCV valve and the elbow on rear side of the throttle body. Oh and make sure you have those new plugs torqued in @ 28ft-lbs
Old 05-16-2011, 07:04 PM
Thanks. It was that coil had gone bad. Runs like a champ now...!
Engine vibration/miss @ idle FX4_Jake 2004 - 2008 F150 3 05-11-2016 10:01 AM
2002 E250 5.4 starts out running fine, crawling in 10 minutes Ryan Simpson 1968-2013 Full Size Vans 15 04-12-2016 07:53 AM
2005 F-150 SCREW cab 4.6L Engine swap Tex Ford 2004 - 2008 F150 0 02-02-2016 09:04 AM
2004 Ford F150 5.4 Triton 3V Vin5 Rough Idle Cylinder 3 Misfire Wildboy402 2004 - 2008 F150 12 12-24-2015 01:42 AM
running real rough and pulled 6 codes 4 misfires mtcrss14 Modular V8 (4.6L, 5.4L) 5 02-26-2010 10:49 AM
Tags
54, 99, check, code, coil, e150, e250, f250, fire, ford, fuel, good, misfire, miss, missfire, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
