fuel bowl drain leaking - Ford Truck Enthusiasts Forums
Old 05-12-2011, 05:24 PM
rivrrunner's Avatar
rivrrunner rivrrunner is offline
rivrrunner is starting off with a positive reputation.
ever since I replaced old screen type fuel filter w/ new paper filter I have a slow leak from my drain tube....any ideas?
Old 05-12-2011, 05:39 PM
UP_There's Avatar
UP_There UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Sounds like the valve wore out, the filter inside would'nt cause a leak. I chased a fuel leak down recently that ended up being a hole worn in the fuel line underneath the bowl
Old 05-12-2011, 05:44 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
Riffraff Diesel: Complete Fuel Bowl Seal Kit
did this last year best money ive spent on PM in a while
edit: i know guzzle has it to but couldnt find it on his site (same kit though)
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Either you didn't close the drain valve all the way or the o-rings are leaking. Here is a link to for replacement parts.
Replacement O-rings for Ford Diesel Engines
You will see a link for installation instructions at the bottom of that page. It's a pretty easy fix.
Old 05-12-2011, 06:05 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Quote:
I see your in Portland. If you order by 4:45pm we can get it to you tomorrow UPS Ground.
Old 05-12-2011, 06:36 PM
Quote:
Dang! That's some awesome service!
Reps if I could....
Old 05-12-2011, 08:32 PM
jtybt jtybt is offline
jtybt is starting off with a positive reputation.
Not too bad on a truck. Now a van will get you talkin' to yourself.
Old 05-12-2011, 09:13 PM
Tailgate77478 Tailgate77478 is offline
Tailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud of
What you need is simply two (2) #202 O-rings, and a Torx bit set to remove the four screws on the drain valve assembly. You *may* want an angled pick to break the seal around the drain hose as they tend to stick onto the metal tube over the years. Just run the pick around the inside to break the seal.
You should use VITON material O-rings if you can get them, but in a pinch you can put rubber O-rings in temporarily until you can order some viton one's online. I think I paid $5 for 25? It was some years ago.
Cheap fix, simple to do, but frustrating if your hands are bigger than a chipmunk's.
Old 05-12-2011, 10:30 PM
rivrrunner's Avatar
ya know iv'e been working like a sled dog and have had zero time lately.... but I knew I could post here and get the answer without a second thought.
Clay, I'm currently in Dickinson ND and will order after I look at it Sunday.
Thank you all!!!!
Brian
Old 05-12-2011, 11:12 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Get the blue ones from Guzz.
The best there is, and likely the very last time you'll ever do that job.
Pop
Old 05-13-2011, 06:59 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
There is actually a third o-ring on the valve stem itself that can leak and should be replaced when you replace the two outer seals. Guzzle's/RiffRaff's kit has you covered.
Old 05-13-2011, 09:40 AM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
I just did this fix, and beware that you need a small ratchet and the correct Torx bit - you cannot use a Torx screwdriver (of the sort used for GM headlight trim). It took a bit longer than I expected, due to the access issues, but the kit and instructions (from dieselorings) were outstanding.
Old 05-13-2011, 10:26 AM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
If your o-rings are leaking at the drain valve, then it is time to replace all of your fuel bowl o-rings. You can over haul your fuel bowl in a couple of hours with the kit from Guzzle and his step by step instructions.
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
rail mounted fuel filter flravem 6.7L Power Stroke Diesel 17 11-17-2016 05:54 PM
fuel Filter Replace 1L243 1999 - 2003 7.3L Power Stroke Diesel 10 10-20-2015 07:34 PM
Does your fuel drain valve leak at knob? golfmedik 6.7L Power Stroke Diesel 34 01-06-2014 08:42 PM
Fuel drain valve leaks... RUSTANG67 1999 - 2003 7.3L Power Stroke Diesel 6 01-17-2013 05:44 PM
fuel filter drain wont drain justin1795 1999 - 2003 7.3L Power Stroke Diesel 6 01-30-2012 03:34 PM
Tags
1999, 73, 95, asemmgly, bowl, change, diesil, drain, f350, fuel, leak, leaking, seals, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
