2002 ford excursion spark plug change - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 05-12-2011, 05:35 PM
95fordXL 95fordXL is offline
95fordXL is starting off with a positive reputation.
I'm getting ready to do a change on my friends 2002 excursion and it has the V10 in it and I was just wondering if you all had any tips on doing it cause i'm sure the very back to will be a pita
Old 05-12-2011, 06:14 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
The rear 2 plugs on the passenger side are awful. Have a good assortment of extensions available - I usually use a 3" on my spark plug socket and put in in the hole. Then have another 2-3" on my rachet and join the two extensions together if that makes sense. It's worse if you have a coarse socket as there isn't a lot of room to swing the rachet to loosen things up. An 80 tooth or higher socket makes things much easier - I actually like this one:
Good luck. I find it easier to actually sit in the engine bay but that doesn't work for everyone.
Old 05-12-2011, 06:18 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I did a write up on it.......do a search. You don't have to have a bunch of wobbly stuff that will just hamper your removal of those back 2.
Old 05-13-2011, 08:29 AM
Nosedive1 Nosedive1 is offline
Nosedive1 is starting off with a positive reputation.
These are some good write ups:
http://www.ford-trucks.com/forums/10...ark-plugs.html
http://www.ford-trucks.com/forums/45...th-photos.html
A wobble extension is a must. Also when doing number 9 and 10 (the back ones on the passenger side) be sure and tape the spark plug socket to the with one wrap of electrical tape. This ensures that they don't seperate and give you grief. I just did mine about a month ago and all the planets must have been in alignment as everything went really smooth. The info on this site is amazing.
Old 05-13-2011, 02:04 PM
The wobbly is not a must, read my post; (the top one above) The wobbly will only make it wishy washy and not a positive feel and lessens the force.
Old 05-13-2011, 02:18 PM
ecoastkid ecoastkid is offline
ecoastkid is gaining momentum as a positive member of FTE.
The only must have tool in this job is an inch pound torque wrench.
This is used for torquing the spark plugs...oh...dont forget the antiseize on the plug threads. Dont follow the above (especially on your 4 thread heads) and you will be asking for a ejected plug.
As for the install?
Personally...I say jack up the fuel rail and lift it high...gives you a lot of room and only takes 2 bolts to do. Plus, you can yank all the injectors and inspect them. Reinstall with some vasoline on each o-ring and it slides back together with a satisfying pop. If you use no lube, you'll wonder if the rail is all the way down.
After all the crap is outta the way, you can sail down the line. Use some dielectic grease on the plug end and harness end of the coil packs (and on the injector connectors)
People make much more of this job then it really is IMO
Old 05-13-2011, 03:30 PM
Quote:
I'm not sure I'd call a flex head rachet from Snap On a bunch of 'wobbly stuff' and the extensions are a requirement. I better go read your write up so I learn how to do something I do on a weekly basis.
Old 05-13-2011, 06:48 PM
Quote:
A straight 3/8" ratchet wrench is the best to get those last 2 out because it is more direct, won't break your plug, applies more torque, and you get a positve feel of what's going on back there. It's not going to hit anything and you can soon spin the plug out by hand by the extension. Maybe all those years of bending wrenchs all day didn't teach me anything .
Snap On flap on, it's just another brand.
Old 05-13-2011, 06:52 PM
Guess not. To each their own.
Old 05-13-2011, 06:56 PM
I hated snap on ratchets because they were too smooth and slippery and hard to reverse but thanks for your photo and contribution, I'm just fussy about my wrench's.
Old 05-13-2011, 07:48 PM
1 Excursion camper's Avatar
1 Excursion camper 1 Excursion camper is offline
1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of
I did mine at 50K. from all the reading and doing them on an F150 of the same year I was expecting them to be a PITA. turns out they were a piece of cake! being built on the F250 platfrom there is plenty of room under the hood. I had mine done 30-40min.! with air tools. the rears are easy. don`t know why everyone says you need special tools? I needed no wobbles or special extensions.
Very easy! very straight forward. no need to remove any fuel rails or get any flexhead ratchets (although if you have one it could be a benefit).
Old 05-13-2011, 08:34 PM
I didn't say special extensions - just that they were needed. Oh well - guess it's just controversy night.
Old 05-13-2011, 08:35 PM
Are you always this way? Seen some of your other posts but thought it was a fluke. Oh well... glad you liked the picture and hope you figure out what good tools are at some point.
Old 05-13-2011, 11:09 PM
Always what way? Anyone that was a mechanic for years knows what a good wrench is. I hate Snap-on wrenches, they are plenty strong but read what I wrote. I never could figure out why people doubt the word of professionals. That was a rediculous statement you made above. Are you always this way? I think you should stick with changing oil and spinning lug nuts.
Old 05-13-2011, 11:11 PM
Just my point; you are better off without the flex head here.
7.3 PSD Swap Project into 2005 V10 Excursion Sunline Fan Excursion - King of SUVs 378 08-21-2014 11:20 AM
Excursion dvd part superdave02f552 WTB - Parts & other 0 07-28-2014 11:47 PM
When did the climate controls change? Pele Excursion - King of SUVs 29 07-06-2014 02:32 AM
2002 Excursion Warm hub installation question JohnnyDiaz Excursion - King of SUVs 12 03-01-2014 09:25 AM
What fluid to use in 4R100 transmission & transfer case 2002 Excursion Excursion - King of SUVs 19 09-27-2013 09:17 PM
Tags
2000, 2002, change, excursion, ford, install, plug, plugs, reading, size, spark, sparkplug, torque, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
