97 f150 overdrive light blinking
Funny things happen.
Get the codes read first.
As an example only; If a certain fuse were to blow from an electrical fault such as a shorted OX sensor heater circuit, it takes power off from the shift solenoids, torque convertor clutch and a bunch of other operations and causes all kind of 'goings on' until someone is smart enough to figure it out.
A trouble like this takes looking at the wire diagram to discover that the power the fuse feeds goes to 'SEEMNGLY" unrelated places until you see in on the drawings.
How it all started was with a string of codes referring to a number of different areas but tuned out to be all common to "one" fuse.
This is a real time example I have already had, that a trans shop could not figure out.
Need to see the codes first to get a direction on the issue. We cannot guess the fix or trouble ahead of it.
Good luck.
Good luck.
Transmission codes are in the 7xx range and not engine related if the issue is in the transmission.
The CEL light may not come on for example if a clutch in the trans is slipping.
It's not electrical in nature so the PCM cannot detect it.
Be sure about it because you are having an issue for some reason.
smashclash
1997 - 2003 F150
45
09-17-2014 02:17 PM
