97 f150 overdrive light blinking - Ford Truck Enthusiasts Forums
Old 05-12-2011, 04:36 PM
memphis_made's Avatar
memphis_made memphis_made is offline
memphis_made is starting off with a positive reputation.
my over drive light is blinking and when i hit 20 it bogs down then u have to stomp on it in it revs back up and gose it says its in 4x4 low on the dash but it doesnt feel like it is idk where to start on this anybody know what this is?
Old 05-12-2011, 06:20 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Need to pull the codes and stop driving it if at all possible. The blinking is the transmission warning light telling you there is a problem.
Old 05-12-2011, 07:34 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Funny things happen.
Get the codes read first.
As an example only; If a certain fuse were to blow from an electrical fault such as a shorted OX sensor heater circuit, it takes power off from the shift solenoids, torque convertor clutch and a bunch of other operations and causes all kind of 'goings on' until someone is smart enough to figure it out.
A trouble like this takes looking at the wire diagram to discover that the power the fuse feeds goes to 'SEEMNGLY" unrelated places until you see in on the drawings.
How it all started was with a string of codes referring to a number of different areas but tuned out to be all common to "one" fuse.
This is a real time example I have already had, that a trans shop could not figure out.
Need to see the codes first to get a direction on the issue. We cannot guess the fix or trouble ahead of it.
Good luck.
Old 05-12-2011, 11:55 PM
no check engine lights are on so i dnt think its throwing anycodes
Old 05-13-2011, 01:35 AM
Transmission codes are in the 7xx range and not engine related if the issue is in the transmission.
The CEL light may not come on for example if a clutch in the trans is slipping.
It's not electrical in nature so the PCM cannot detect it.
Be sure about it because you are having an issue for some reason.
Old 05-13-2011, 11:34 PM
its weird i un hooked the battery to reset it because it wouldnt start now its shifts fine no blinking light nothing i think i have some electrical issues
PATS issue? Truck won't start after changing plugs and COPS smashclash 1997 - 2003 F150 45 09-17-2014 03:17 PM
4x4 low light blinks all the time awillo0406 Explorer, Sport Trac, Mountaineer & Aviator 0 04-03-2013 08:41 AM
ABS light is on and 4x4 light blinks Branny08 Escape & Escape Hybrid 6 04-02-2012 08:02 PM
ABS, light is blinking Dutter Ranger & B-Series 8 07-27-2011 12:38 PM
ABS blink code rgb1963 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-30-2001 08:24 PM
Tags
2003, 42, 97, blinking, bogging, drive, f150, flashes, flashing, flickering, ford, light, od, overdrive, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
