Dana 70 vs. 70HD vs. 80 diff cover. - Ford Truck Enthusiasts Forums
Old 05-12-2011, 04:36 PM
kjgibson2's Avatar
kjgibson2 kjgibson2 is offline
kjgibson2 is starting off with a positive reputation.
I'm wanting to get an after-market diff cover for my dana 70HD, I was wondering if it is the same cover as a Dana 70 or possibly a Dana 80 because I cannot find a clear cover listed for the HD. Thanks.
Old 05-13-2011, 03:11 PM
zooom zooom is offline
zooom is starting off with a positive reputation.
RE: differential cover
I have a Dana 70HD in my '06 MH and it takes the same cover [i.e.,a Mag- HyTek] as my '01 Dodge Ram 2500's Dana 80. Trouble with the cover in the MH was sway bar/gas tank interference, so I kept the OEM one instead. The Mag HyTek cover offered an additional 4-5 qts gear lube capacity which would have been nice -- if the cover fit!
Old 05-16-2011, 02:34 PM
kjgibson2's Avatar
Quote:
So the bolt pattern is the exact same between the 70HD and 80? Just want to make sure before I order a cover. Thanks
Old 05-16-2011, 03:40 PM
fyerser fyerser is offline
fyerser is starting off with a positive reputation.
While we're on the subject of d70s, how can i tell what kind of d70 is in my truck? I don't know if it's a basic d70, or d70u or what. It's an '83 f250 4x4.
Old 05-24-2011, 03:24 PM
kjgibson2's Avatar
My pumpkin was stamped 70HD in the top left corner looking into the pinion, your's may be similar
WTB: E350 dana 70HD srw axle 92-07 Iowa rebar13 WTB - Parts & other 5 02-14-2015 05:46 PM
Wondering about a disk brake conversion 1972fordhighboy 1967 - 1972 F-100 & Larger F-Series Trucks 4 02-05-2015 06:26 PM
Gaskets for Sterling 10.5. & Dana 50 miko6810 Excursion - King of SUVs 12 01-15-2015 10:37 PM
Differential Covers Boom48 1999 - 2003 7.3L Power Stroke Diesel 46 10-22-2014 02:39 PM
Differential Numbers D70 Gordilocks 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-26-2005 09:36 AM
Tags
70, 70hd, 80, cover, covers, dana, diff, differential, dodge, hd, measurements, oem, parts, ram2500, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
