04 F150 engine noise under load any speed - Ford Truck Enthusiasts Forums
Old 05-12-2011, 02:33 PM
Pawdog75 Pawdog75 is offline
Pawdog75 is starting off with a positive reputation.
I cannot find the exact issue so here is my problem 2004 f150 5.4 and under a load at any speed even the slightest incline Im getting a rattle somewhere under the hood cant tell if its left side or right? If I let off the gas it stops, and if i give it more gas and get it to downshift it stops! It has been doing it more and more not sure if its cause I have had the A/C on or what! Its not a rattling heat shield, sounds like air, OR???????
<!-- / message -->
<!-- controls -->
Old 05-16-2011, 10:45 AM
FYI last fill up I put 89 octane in and the rattle has gone away so far!!
Engine rattle @ high rpm under load Schnurrbart Ford Inline Six, 200, 250, 4.9L / 300 28 03-11-2017 07:55 PM
Loose, rattling back doors and window - FIXED! billionj Excursion - King of SUVs 0 10-24-2016 11:58 AM
04 makes rattling sound when on the gas.?!? Hendog 2004 - 2008 F150 15 10-04-2016 02:54 PM
2008 Shift knob rattling... TexasRebel 1999 to 2016 Super Duty 2 01-06-2012 04:06 PM
That's weird, I thought it was supposed to ping under load.. wwracer 1987 - 1996 F150 & Larger F-Series Trucks 2 10-26-2011 09:32 AM
Tags
04, 351, 54, 99, engine, f150, f250, ford, knock, load, max, metallic, noise, rattle, speed, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
