Freeze plug - Ford Truck Enthusiasts Forums
Freeze plug
Old 05-12-2011, 11:08 AM
1993f-250's Avatar
1993f-250 1993f-250 is offline
1993f-250 is starting off with a positive reputation.
Freeze plug
I need to replace the freeze plug that's behind my driver side engine mount. What's the best way to go about doing that? I have the old one out already. It's a 1993 F250 460ci
Old 05-12-2011, 04:01 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
The hardest part is getting the old one out. The new one should just be tapped into place.
Old 05-12-2011, 04:25 PM
jokerforever's Avatar
jokerforever jokerforever is offline
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
I had my block heater blow out last year on my 350. I replaced it with a freeze plug but wasn't able to get anything in there to knock it in. I ended up having to unbolt the exhaust from the manifold and cutting it at the straight part under the oil pan. With that out of the way I just used a big socket and tapped in the freeze plug. I reinstalled the exhaust by using a sleeve and clamps on the part that I cut. I would suggest replacing the heat shield (you'll have to remove it with the exhaust) or using something else (maybe wrap). It looks like the exhaust heat has dried out my rear seal. Oh, and be careful tapping in that freeze plug. It's easy to go too far and push it into the block.
Old 05-12-2011, 05:09 PM
1993f-250's Avatar
Ya I know how to put the freeze plugs in. I put These ones in when I rebuilt the engine. But as it turns out the machine shop gave me the wrong size freeze plugs. What I need to know Is if there's any way to get up behind the engine mount to put that particular one in or how I should go about it. It's the freeze plug on the driver side under the engine mount. I believe 2nd from the rear of the block.
Old 05-12-2011, 05:17 PM
redmondjp's Avatar
redmondjp redmondjp is offline
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
ATD Tools 5270 Freeze Plug Installation Tool
I can't tell you the number of times that I could have used this tool (which I still don't own BTW)!
The other option is to install an all-metal expanding type of plug, but these are pretty hard to find and tend to seep a bit in my experience.
freeze plugs popping out chickenlegs 1999 to 2016 Super Duty 14 04-13-2015 11:29 AM
Freeze plugs leaking. 77f250weos 1973 - 1979 F-100 & Larger F-Series Trucks 18 09-21-2013 02:48 PM
throttle body freeze plugs leaking szealuss 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2010 11:40 AM
1994 F-250 V8 460 - Freeze Plug handymanken 1987 - 1996 F150 & Larger F-Series Trucks 2 09-07-2010 11:02 AM
Fuel pump block off freeze plug Brians97F250Crew 1994.5 - 1997 7.3L Power Stroke Diesel 2 02-16-2010 10:50 PM
Tags
1990, 30, 58, 96, change, engine, f150, f250, ford, freeze, frost, liter, motor, mount, plug, plugs, ranger, soft, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
