how to test if PCM needs to be replaced? - Ford Truck Enthusiasts Forums
Old 05-12-2011, 12:27 AM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
hey guys, this is where i'm at now
i had wts light work this morning, stop working for a bit, now its not coming on again. all fuses are OK.
Old 05-12-2011, 01:41 AM
bluescrew's Avatar
Batteries are almost charged up, will put everything back in the morning
Old 05-12-2011, 08:38 AM
dcf4x4's Avatar
dcf4x4 dcf4x4 is offline
dcf4x4 has a good reputation on FTE.dcf4x4 has a good reputation on FTE.
My driveway test through experience:
If your fuel pump doesn't run, no wts light, no tach on the 99-2002 trucks, and no glowplug... it's a good bet it's your PCM.
Ford wants 750 plus 80 for tuning... Junkyards don't have any because it's a high demand piece....
Good luck.
Old 05-12-2011, 08:56 AM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
If it is your PCM here is a very good resource for a PCM replacement.
Auto Computer Exchange - Auto Computer Superstore - Cheaper than dealers and mechanics.
Old 05-12-2011, 10:08 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Car-part.com is a great source for PCM's.
List of PCM Codes. Any PCM from 99-01 will work for you, try to find an NVK4 if you can.
Old 05-12-2011, 10:37 AM
DB Guy DB Guy is offline
DB Guy is gaining momentum as a positive member of FTE.
PMT stradigys have better shifting IMHO...
Old 05-12-2011, 10:58 AM
bluescrew's Avatar
would a fried PCM make is so that i cannot use a code reader?
Old 05-12-2011, 11:10 AM
Quote:
Your favorite tuner disagrees
Old 05-12-2011, 11:11 AM
bluescrew's Avatar
oh man. no one in the friggen city has one.
Old 05-12-2011, 12:23 PM
Well David likes MNM... And Swamps was PMT... I cant tell you who my fav is...
Trouble maker.
Try some of the wrecking yards for a PCM... Should be able to get something there, anything from 99.5-2001 auto will work, dont let them tell you it has to be the same year, or code or else...
I still dont think its your PCM but who knows.
Old 05-12-2011, 12:49 PM
Trouble maker.
Hi Pot, my name is Kettle. How are you?
bluescrew, hopefully you get this sorted soon, I can only imagine how frustrating this must be. Check all the fuses over religiously, quintuple check all the wiring connections, and take it from there. I'm guessing whatever the problem is will make you slap your forehead and think "how the EFF did I not think of that?" but who knows.
Old 05-13-2011, 12:05 AM
White 99 White 99 is offline
White 99 is starting off with a positive reputation.
I almost lost $600 to those guys. Check google for complaints and check BBB.
Auto Computer Exchange, Inc. Business Review in Davie, FL - South East Florida BBB
I am not sure but I suspect they also use other names.
Old 05-13-2011, 12:13 AM
dcf4x4's Avatar
A fried PCM will disable the scanner port.
The scanner talks to the PCM. The PCM isn't taking visitors anymore cause it's dead.
My PCM had some sort of hiccup inside it. The only warning was two weeks previous; the fuel pump burned out and after replacement the truck spent those two weeks hiccuping. That was followed by three days of false hope and easy driving, then KAPUT, coasting to the side of the road in sadness and broken trust.
Not trusting my truck is a horrible feeling.
Fuel gauge not working Tvertiz 6.7L Power Stroke Diesel 1 08-15-2016 04:17 PM
sync not working cdmm151 2009 - 2014 F150 40 08-03-2016 09:49 AM
New Ford Owner fillup_951 New Member Introductions 3 04-12-2016 04:20 PM
Speedometer not working. 1994 Ford F150 XLT Loganc95 1987 - 1996 F150 & Larger F-Series Trucks 8 06-10-2013 03:43 PM
Speedo wont work albinorhino 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-09-2012 10:39 PM
Tags
03, 2000, 2001, 73, 97, control, f150, f350, ford, fried, module, pcm, power, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
