1997 f150 check engine light on - Ford Truck Enthusiasts Forums
Old 03-23-2003, 08:18 AM
6T8STANG 6T8STANG is offline
6T8STANG is starting off with a positive reputation.
Question 1997 f150 check engine light on
Have a 1997 f150 with the 4.6l automatic transmission with about 86000 on the engine. The check engine light came on, so I had a computer check done. The check came up with EGR. I had the EGR replaced and the check engine light shut off. A day later it came on again. Had the computer checked again and the same thing came up, the EGR. Any help would be great. THanks
Brian
EGR COOLER P0401 code diesel stopper 6.7L Power Stroke Diesel 3 03-16-2016 02:33 PM
Major idle problem Brian Ski 44 1987 - 1996 F150 & Larger F-Series Trucks 2 08-25-2015 09:54 PM
6.4 Lack of Power/No Boost jatsie 6.4L Power Stroke Diesel 17 07-27-2014 11:28 AM
1997-2005 5.4l 2valve engines and rough idles Longdistancetrucker 1997 - 2003 F150 0 02-17-2012 11:44 PM
Dpfe problems 6T8STANG 1997 - 2003 F150 4 06-28-2003 06:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
