You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can you check fuel presure somehow? Even if you have to put a scredriver into the fitting to release the presure, and then listen to the pump. You might find that you should be chasing spark, if so, I would go after the CPS.
They did have then on cars and trucks. It worked with the oil pressure switch. big trouble with them., always messing up so they stoped using most of that type of system.
__________________ http://www.ford-trucks.com/user_gall...id=170058&.jpg ( TIM ) 2005 F 250 KING RANCH SUPER DUTY 4 DR. CREW CAB. 6.0L PSD. custom paint,custom sound system,24"wheels,nerf bars,hard cover with wing,custom hood.and alot more. took 42 trophies.
Well it turns out that the fuse that goes to the PCM was blown, fixed that only to have it blow again. Then after much wire tracing, found a wire that goes to the PCM had rubbed itself into a ground short. Which in turn took the PCM with it. So, new PCM, new fuse, and just because it's fun, a new coil pack for #8, and the thing runs.
__________________
Mike - 2000 4x4 CC LB F-350 7.3L SuperChips Flashpaq, 4" turbo back exhaust, 6637.
Quote:
Originally Posted by Toyman
Dude you get thirsty at mid swallow of your beer, don't hide it.......
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
