ect sensor location - Ford Truck Enthusiasts Forums
ect sensor location
Old 05-11-2011, 07:24 PM
stanton3 stanton3 is offline
stanton3 is starting off with a positive reputation.
ect sensor location
Hey guys got a couple quick questions.
This truck is a 1990 f250, it has the 5.8 with the m5od 5 speed.
Where is the coolant temp sensor located on this truck? The gauge is dead in the cluster. Is this a common problem or is it more likely for the gauge to be bad?
Thanks guys
Old 05-11-2011, 08:27 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
I would guess gauge, but the ect should be in the intake manifold up close to the radiator hose.
Old 05-11-2011, 11:29 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The ECT is close to the rad hose but that's not what drives the dash gauge.. it has a seperate single wire sensor that sits right in front of #5 injector on the lower intake.
Aftermarket Gauge Sensor Locations countrycar 6.0L Power Stroke Diesel 2 12-20-2016 06:51 PM
1999 F250 Transmission Test Port Temp Gauge garsm 1999 to 2016 Super Duty 18 10-07-2016 10:03 AM
94 bronco temp sensor bh70116 1978 - 1996 Big Bronco 3 08-29-2010 07:32 PM
aftermarket oil pressure gauge pressure sensor location 390 FE zak8tac 1973 - 1979 F-100 & Larger F-Series Trucks 8 06-21-2010 09:31 AM
Coolant temperature sensor location musickerns 1997 - 2003 F150 1 05-20-2009 06:15 PM
Tags
1990, 1994, 2005, 50, 60l, bad, colant, coolant, ect, engine, f150, f250, ford, location, senser, sensor, sensorr, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
