anti-freeze in injector hole
Old 05-11-2011, 05:52 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
Before installing injectors, we sucked out the back injector hole and looked like antifreeze was in the suction tube. Is it normal after sitting for 2 weeks waiting for the new injectors to find a bit of anti-freeze in there?
Old 05-11-2011, 06:05 PM
fordpride's Avatar
fordpride
fordpride is offline
You sure it's antifreeze and not diesel if it's antifreeze then you might have a cracked injector cup.Take a good look at that cup with a bright light
Old 05-11-2011, 06:09 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
kinda thought it was diesel but hard to tell with the mixed in oil. what are symptoms of a cracked injector cup
Old 05-11-2011, 06:13 PM
Action4478's Avatar
Action4478
Action4478 is offline
May want to pressurize the cooling system then take a look...
Old 05-11-2011, 06:17 PM
fordpride's Avatar
fordpride
Rick i think he might have the injectors back in
OP do you still have the injectors out
Old 05-11-2011, 06:21 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
yeah there back in. its the back injector on the drivers side i cant see in there even with a mirrior, wasnt having problems before, sure hoping it was diesel
Old 05-11-2011, 06:48 PM
Action4478's Avatar
Action4478
You can still run the test see if it holds pressure .. If its leaking , you will end up with fuel in the de gas bottle ...
Old 05-11-2011, 06:54 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
how do i pressurize it?
Old 05-11-2011, 06:58 PM
fordpride's Avatar
fordpride
With a coolant system pressurer tester you can go to Autozone and rent one
Old 05-11-2011, 10:58 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
sure hope it was diesel. i ran it and dang she runs good. if it is a cup problem what kind of symtoms should i be seeing? thanks
Old 05-12-2011, 11:33 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
I think that Rick answer that in post # 7
ovenrat
1999 to 2016 Super Duty
07-13-2014 09:28 AM
oldbird1965
01-01-2012 12:20 AM
jchamb11
24
09-30-2011 06:56 AM
jacksnicky
06-11-2011 01:12 PM
searchingforpowe
Modular V10 (6.8l)
24
07-06-2005 09:16 PM
Quick Reply: anti-freeze in injector hole
