Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-11-2011, 04:44 PM
mongjla mongjla is offline
Garage is empty, add now
mongjla is starting off with a positive reputation.
Fuel filter on '08 Expedition
Dropped off my wife's '08 Expedition EL Limited at dealer this morning for oil change. Maintenance schedule from Ford recommends change of fuel filter at 30K miles, so asked for that to be done as well. When I received a call from garage to let me know vehicle was ready for pickup, the serviceman told me the fuel filter wasn't changed since vehicle "doesn't have one." Is this true? I was a little irked that they charged me $27 for "labor" to change fuel filter. Shouldn't they have known there wasn't any filter before trying to replace it?
  #2 (permalink)
Old 05-11-2011, 09:49 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
The 07-09 Expeditions do have fuel filters. 2010+ models have them built into the fuel tank. I know on my 07 the fuel filter is on the inside of the frame rail right under the driver seat area. It is probably the same on the 08.
So the dealership charged you $27 to find out that your car supposedly does not have a fuel filter??? It might be time to find a new dealership.
__________________
2007 Expedition Limited White Sand
  #3 (permalink)
Old 05-11-2011, 10:02 PM
Take this to them and ask them what number 11 is if your car doesn't have a fuel filter.
Click the image to open in full size.
__________________
  #4 (permalink)
Old 05-12-2011, 07:35 AM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
If they charged you $27 labor for something they didn't do, you should be back their pronto for a refund. They can either change the filter that's there for what you paid, or they can refund your money for something they admit they didn't do.
They pretty much "stole" $27 from you.
__________________
Firefighter/EMT IAFF Local 4392
"I've done a fair share of stupid things in my life, a couple of which should have put me in my grave. But here I am typing away as if I had a brain." - Craig Wilson
  #5 (permalink)
Old 05-17-2011, 11:13 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I have changed mine twice. They are lying. Tell them you will report them to the DOCA or whatever agency your state has for auto repair fraud.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #6 (permalink)
Old 03-02-2012, 11:31 AM
Bopper's Avatar
Bopper Bopper is offline
Bopper is starting off with a positive reputation.
I have been screwing around with #18 & 19 in the above diagram for a while now. I cannot get them off. I have the tool for #15. What is the trick for 18 & 19?
__________________
2008 Expedition EL Limited 4x4, Black on Black, Moonroof, Rearview Mirror Camera, Power Liftgate, Luggage Rack, Purchase Date 1/09
Pioneer AVIC-900BT w/ Rear 10.5" DVD/Monitor
  #7 (permalink)
Old 03-05-2012, 07:22 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
There is a tiny barb on the end of the clip that locks it in place. Look at the new filter clips and you will see what I mean. Its a bit like a safety that prevents the clip from falling out. Try squeezing the ends together while lifting the clip up. I use a small screw driver to lift it up. Be gentle or you'll break something.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #8 (permalink)
Old 05-13-2012, 01:02 PM
ptmares ptmares is offline
2007 Ford Expedition
ptmares is starting off with a positive reputation.
This is for my 2007 Expedition EL. What tool is the best to use when removing the fuel filter? What size is the fuel line? How do I relieve the pressure within the fuel line?
Thanks, Ptmares
  #9 (permalink)
Old 05-13-2012, 05:57 PM
gwells89 gwells89 is offline
2008 Ford Expedition
gwells89 is starting off with a positive reputation.
OEM/Fuel line disconnect set for Ford and GM. Auto Zone will loan you the tool for deposit and credit back when you return it. Their is a valve on the fuel injectors on the drivers side. It is used for checking fuel pressure and relieving it. I just let the fuel come out when pulling apart.
Tags
06, 08, 09, 2008, 2010, change, el, expedition, filter, ford, fuel, labor, location, navigator, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
