79 ford f150 body lift - Ford Truck Enthusiasts Forums
Old 05-11-2011, 11:27 AM
79-460-f150 79-460-f150 is offline
79-460-f150 is starting off with a positive reputation.
now before i get yelled at i used the search option and i cant find anything i am a new member but have been reading for a year or two now i finally have my first question i want to put a body lift on my truck i want to put a 3inch kit and was wondering if anyone with a 79 ford f150 has done this what they had to do if any modifications to its an auto i know noone likes body lifts but i already have a supension and want 40s
Old 05-11-2011, 11:46 AM
78 PEB's Avatar
78 PEB 78 PEB is online now
78 PEB is gaining momentum as a positive member of FTE.
Although I'm not a fan of body lifts, I'll offer what I know. 1st, the bed is the easy part. 2nd, You may have to lengthen, or straighen out some brake lines to get them long enough. 3rd, Your 4x4 shift boot probably wont work correctly anymore due to the "shorter" shifter. 4th, Not sure what youre going to run into with the steering shaft from the column to the gear. 5th, Im sure you will have to lengthen the shift rod from the column to the trans. 6th, You will no longer be able to use the stock radiator shroud. 7th, Please don't be one of those guys who is too lazy to build different bumper mounts to keep from having the bumpers 3-4" too low....................That just looks hideous............
Old 05-11-2011, 12:03 PM
mudder460's Avatar
mudder460 mudder460 is offline
mudder460 is gaining momentum as a positive member of FTE.
Let me add on: you are going to have to extend your fuel filler neck. Keep an eye on your wiring as well when you lift the cab. The shroud might be useable if you cut the bottom out of it to clear the fan. As for the short sifter, you will have to modify the boot and maybe open the hole in the floor a bit for proper movement.
Old 05-11-2011, 07:57 PM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
For the shroud to do it properly you should move the old one down and cover up the gaps at the top and at the bottom... that would be the easiest way if you ask me. Otherwise your talking about cutting it in half and then filling the gap between the fan and the top of the shroud and filling the gap at the bottom of the shroud and fliing the gap between the two pieces. Or you could make a custom fan shroud. Or you could get electric fans
body lift on a 2wd 'i think i screwed myself" 79 f-150 guy 1973 - 1979 F-100 & Larger F-Series Trucks 21 01-22-2016 12:05 PM
2 or 3 inch body lift on my 79 f150 bigcountry62 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-22-2013 12:29 PM
post pics of ur 73/79 f150 on 38.5 1979fordf150rebel 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-31-2012 10:29 AM
Body lift 79fordf250pickup 1973 - 1979 F-100 & Larger F-Series Trucks 50 05-28-2011 06:44 PM
3inch body lift on 79 f-150 1978fordf250 Offroad & 4x4 14 12-10-2006 03:19 AM
Tags
1979, 2011, 4x4, 78, 79, body, bodylift, bottom, f150, f250, fan, ford, gap, lift, lifts, shrud, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
