5.4l to 400 (335 series) 4r100 bolt up?
2001 F350 4x4
Ok I am issues with the 5.4l and I got a good deal lined up on a built 400 but I am not sure if it will work with my transmission 4r100. bellhousing / torque converter, starter to flex plate alignment. I know I have to throw an stand alone for the transmission.
Not only tranny, but engine computer, and all the other electronics on a modern Superduty.
Then you have power steering, alternator, AC, you name it.
You COULD use an E4OD (with a computer for the 400) instead of the 4R100, that has the right bellhousing pattern (I think they do actually exist), but you'd still be up a creek on all the other stuff.
2001 F350 4x4
Yes...additionally it would be considered an illegal engine change since that specific engine was not offerred.....the best hope would be to go for an exemption at a federal referee station but that would be very, very unlikely and would be impounded at the facility as well!
OP is in Iowa. Best I can tell, there are no smog inspections in Iowa. Couldn't find anything on their DMV site and the private sites say no inspection.
SINCE WHEN is there any FEDERAL smog inspection as alluded to in the prior post?
SINCE WHEN are vehicles being impounded for failing smog? In CA, you simply can't renew your registration. If you try to import a non-approved vehicle into the US from a foreign country, you risk impoundment from the Feds--otherwise, it is up to the states to enforce the law. And that is almost alway via the registration process.
So, OP can put that 400 in there--which, imo, is a bad idea, but the smog check will be the least of his worries.
If impounded by epa, fish & game, USDA, any law enforcment (local, state, federal) or even a local/state/federal fire inspector can impound, you basically have no rights...you get to go to court, sit there while a judge decides if the vehicle will be scrapped or not and then, you get to sit and listen while the judge decides what all your fines, fees and assessments will be.....typically they start at about $3000
This isn't calif law, this is federal, that is enforced by states, counties or cities.
[QUOTE=85e150six4mtod;10359695]Do you have a link to any story or statistics relating to such impounds?[/QUOTE
Those stats are reported at each state web site. or better yeat, place a call to your local fish & game warden....you would be amazed at the document they carry to enforce these regs......even has color pics to ID illegal engine swaps.
This is not anything new, been going on for almost 20 years- enforcement levels are different varying by who is working the each area and how your luck is running!
OK, but it looks like you are usually subject to this kind of impound in connection with some other incident. An accident, or getting arrested street racing, for example--they always make a big scene out of those.
Anyway, I think the point has been made that this is not a good swap, up to the OP if he wants to chance it.
Thanks for the update.
shaneandsarah
1997-2006 Expedition & Navigator
03-07-2017 01:14 AM
dalfollo
26
11-03-2016 09:44 PM
Mark W. Ingalls
11-14-2015 09:12 AM
PPrash
1999 to 2016 Super Duty
12-06-2009 09:46 AM
