heater blend door
Old 02-11-2011, 06:25 PM
sammiestoyz's Avatar
sammiestoyz
sammiestoyz is offline
heater blend door
looking for the fix that i heard about, to repair a broke blend door
Old 02-11-2011, 06:57 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
e-bay......has the door by itself for very cheeeeep....you can shave the teat off the bottom and wedge it in and save a bunch of money. You will want to buy a new condenser b/c the installation that is wrapped around has caused it to rust past the point of saving. And don't forget to get some R-22 of course
Old 02-12-2011, 06:11 AM
tomw's Avatar
tomw
tomw is offline
The specific refrigerant mentioned, R22, is the soon-to-be replaced home A/C - Heat Pump refrigerant, and has never been used in trucks or cars.
The condenser is mounted out in front of the radiator, not in the A/C plenum.
Check further down the main forums page for the Heating and Air Conditioning sub-forum. There are several methods to repair the blend door, from cutting the plenum to applying a 'splint' using glue and essentially popsicle sticks - if I remember correctly.
There was someone selling a 'kit' on ebay, and they may still be offering it for sale. Wouldn't hurt to check.
tom
Old 02-12-2011, 06:28 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Yes sir! R-134a. I musta had a brain TRAF last night, lol
R22 is out then 134 is next to get the axe then 410 will be in untill a better blend is deemed fit in Uncle Sam's eyes.
Old 02-12-2011, 06:37 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Old 02-12-2011, 07:00 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
heatertreater.net also sells a kit but it is not cheap
Old 02-12-2011, 07:10 AM
03 Maz B23's Avatar
03 Maz B23
If you want to go a cheaper route (no guarantee how long this fix would last) you can check out this link.
Free Ford Blend Door Fix
Old 02-12-2011, 09:44 AM
michigan66's Avatar
michigan66
michigan66 is offline
Welcome to FTE. As you can see, you can get lots of help. This is a great source of information about Rangers.
There is a source of info about fixing the blend door right here on the FTE site. Go back to the Ranger "index" page and click on "Technical Information." Scroll down to the Misc. section and keep going until you come to "Blend door fix" and there is an answer.
Good luck.
Old 02-12-2011, 08:14 PM
sammiestoyz
blend door fix
thanks to all for the info and help. will attempt a repair tomorrow .
Old 05-12-2011, 04:48 PM
kdwyer's Avatar
kdwyer
kdwyer is offline
Hey all -
I purchased the new blend door from Oreilly's auto parts. $10.99. I have the old blend door out and it was broken where it meshes up with the blend door acuator.
My question is will the new door be able to have enough play to pop the bottom pivot in? I can feel the top part op blend door in the top hole with one hand while trying to get bottom pivot in place. I dont want to break off bottom pivot. Do I need to be more forceful while trying to get the blend door in? Thanks for all the help in advance.
Old 05-12-2011, 06:48 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
I was not aware the blend door itself could be purchased thru the chain auto parts stores..... Interesting.
On the other hand, the horror stories about the blend door issues make me kinda glad my truck has dealer added A/C. Cable operated blend door, like the non A/C trucks.
Brian Frank
05-24-2016 06:41 PM
SeaCarr
04-21-2016 10:44 PM
ladyexpedition
1997-2006 Expedition & Navigator
10-09-2011 10:04 PM
Snooze
Aerostar
08-20-2011 02:57 PM
billsranger97
12-20-2006 06:23 PM
Quick Reply: heater blend door
