Overdrive transmission in a 1950 M68 - Ford Truck Enthusiasts Forums
Old 05-10-2011, 09:50 PM
ColinJH ColinJH is offline
ColinJH is starting off with a positive reputation.
Hi,
I'm the owner of a 1950 Mercury 1 Ton Truck. I'm restoring it with the idea of keeping it original, but I'm thinking about possibly putting in an overdrive transmission. My reasoning for possibly going this route is that the original transmission is geared so low that first gear is almost unuseable....truly...bull low!
Has anyone done such a conversion? Would an overdrive transmission from a '56 Mercury pickup be adaptable to my older Merc? Is there an overdrive transmission that someone may have used with success?
Thanks,
Colin
Old 05-10-2011, 10:19 PM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
Hi ..and congratulations on your truck..there are some threads about overdrive trannys but dammed if I can figger out how to give you a link ..someone here will help you you just got to wait for them to get off work ..or up from their nap (the retired one's)..good luck ..oh and welcome to FTE
Old 05-10-2011, 11:28 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
First of all, welcome. Glad to have you drop in.
The more traditional way to improve road speed is to swap out your stock Timken axle for a 1967 to 1972 F-250 Dana 60 axle. It's pretty much a bolt in swap, and saves you the expense of an o/d. An added plus is the fact that you'd get rid of your stock 14" rear drums which required the F-3s/M-68s to have 17" wheels. The 17" wheels are the dangerous "widowmaker" variety that most shops won't touch these says. The replacement Dana 60 will have 12" rear drums that will accept any F-250 16" one piece wheel having 8 lug x 6.5" pattern. Stu
Old 05-11-2011, 03:32 AM
kenjh's Avatar
dib's on the widow's !!!!!
Old 05-11-2011, 05:47 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
This thread is a really good place to start: http://www.ford-trucks.com/forums/10...-progress.html Also, if you have the 4 speed, first gear was not meant for anything other than getting heavy loads moving. It was not intended for normal driving.
Old 05-11-2011, 07:59 PM
kenjh's Avatar
first gear is great for rush hour traffic.....wasn't someone talking about puting in a 5 speed trans behind a flathead a while ago??
Old 05-12-2011, 07:12 PM
38 coupe's Avatar
There are two 5 speed discussions I am aware of.
1 - T5 from a mustang, S10, etc. In order to install one you will have to cut your cross member. Also, the preferred shifter location is with the S10 tail housing but the good gear ratios are from the world-class mustang box. Lots of people have done this and like the results. I think it always looks tacked on, not right. I don't like cutting frames either. I'm a purist to anyone but a true purist.
2 - The "medium duty" five speed from 53 2 ton trucks. These are still big transmissions. There are direct drive and overdrive versions of these. These also take a one year bell housing with a different clutch setup and bell housing located motor mounts. In order to fit, you again have to cut the cross member. At least you would be getting a truck transmission, but way too much modification for the gain.
The three-on-the-tree with overdrive transmissions will also require you to cut the cross member. The only version I am aware of that will hook up to your existing bell housing and clutch linkage is the 49-early 51 Mercury overdrive transmission. I purchased one of these years ago before I realized I would have to cut the cross member. I'm still not ready to sell it, but I'm definitely not cutting my frame to install it.
If you are dead set on having more gears, you can get a Brown-Lipe auxiliary transmission and shoe horn it under your bed, replacing the middle u-joint. I used to think these transmissions were too big to do this, but then I saw pictures of one mated to a T-9 (the four speed crashbox transmission most likely in your truck) and they are about the same hight and width. I don't recommend mounting it like this guy did, but here are the pictures: Untitled Document
Depending on how fast you want to go, get either a 4.10 ratio or a 3.54 ratio Dana 60.
Old 05-14-2011, 09:27 PM
Hi,
Thank-you so much for all of your replies regarding my question about an overdrive transmission for my 1950 Mercuty 1 Ton. I feel incredibly fortunate to be connected with such experience and knowledge!
What might I expect to pay for a Dana 60?
Appreciatively,
Colin
Old 05-15-2011, 09:31 AM
38 coupe's Avatar
I paid $400 for a 4.10 ratio one out of a '66 F-250. Price is probably heavily dependent on what area of the country you are looking though.
Old 05-15-2011, 11:37 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.Rusty_Old_F250 is gaining momentum as a positive member of FTE.
I would suggest searching Craigslist in your area, see if you can find someone parting out an F250, they'll usually let the axle got for pretty cheap. I've read that you want to avoid the 1973 and later axles, as they are wider and won't fit the older trucks as good, look for one from a 57-72 truck.
Sam
1949-1951 Mercury Overdrive fifty-two_f1 WTB - Parts & other 0 12-27-2015 10:23 PM
91 F-150 no overdrive at 65mph? jtyson8602 1987 - 1996 F150 & Larger F-Series Trucks 24 09-24-2013 12:09 PM
5 speed clark questions bigvinnie 1961 - 1966 F-100 & Larger F-Series Trucks 11 11-06-2005 02:34 AM
Gear Vendors shifting? jdbanks Clutch, Transmission, Differential, Axle & Transfer Case 8 06-30-2005 05:54 PM
Mitchell Gear Splitter work for overdrive in 67? jdbanks 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-16-2005 07:49 PM
Tags
1950, 1950s, 1952, buy, conversion, ford, m68, mercury, ocerdrive, overdrive, trans, transmision, transmission, truck, wannt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
