84 bronco back fired then quit - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 05-10-2011, 08:53 PM
Loud4.9's Avatar
Loud4.9 Loud4.9 is offline
Loud4.9 is starting off with a positive reputation.
Hello folks had my bronco II stuck to the nuts the other night had it floored trying to get out it back fired and would not start after. Towed it home cheaked spark got good spark , cheaked im getting fuel, I cheaked one plug hole got 120 psi compression. For the sake of it i put new plugs in it today tryed starting it would just back fire every now and then. Any idea's ?
Old 05-11-2011, 12:40 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Does your engine use a timing chain or gears? A good backfire will cause the timing chain to jump a tooth or more if it's loose. Check your timing--if it's way off, check further.
Old 05-11-2011, 01:12 AM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
2.8 uses timing gears made of a odd fiber material in stock form, and can disintegrate with age and redline rpms. I would start looking at more mundane things first like ingestion of water or a TFI module that died.
Old 06-12-2011, 06:31 PM
Loud4.9's Avatar
Okay so alittle update I pulled distrubtor out and found the gear to be destroyed anybody no typical how much damage does this cause ?
Old 06-12-2011, 07:23 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Most of what you see missing is in the oil system...that is not good.
IMO pull the oil pan !
Old 06-12-2011, 07:43 PM
Old93junk's Avatar
Tear down time, the camshaft will be trashed too, lots of filings in the oil.
Decision time: trash it or fix it.
Old 06-12-2011, 08:14 PM
IB Tim's Avatar
Site Administrator
Fix it ..
Old 06-13-2011, 07:45 PM
Loud4.9's Avatar
Well that sucks i got a spare motor but i might try out a 4.0 swap
Old 06-14-2011, 07:55 AM
IB Tim's Avatar
Site Administrator
Seems like a bit more work to go 4.0 the pop the other one in
1995 Bronco bad bog @ 2500 rpm Loud4.9 1978 - 1996 Big Bronco 8 08-27-2011 10:32 PM
New Injector Not starting now. Bad PCM? garsm 1999 - 2003 7.3L Power Stroke Diesel 11 06-30-2011 06:35 PM
84 Bronco 2 no spark Loud4.9 Bronco II 5 09-13-2010 08:23 PM
85 Ranger 2.8L No Spark Ranger_85 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 10 08-20-2007 11:39 PM
starter bronocIInoob Bronco II 6 12-20-2005 09:58 PM
Tags
1980, 1984, 1985, 84, back, backfire, backfired, brocnco, bronco, cylinder, fires, ford, ii, redline, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
