Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2003, 11:45 PM
reddogracing's Avatar
reddogracing is starting off with a positive reputation.
Question wheel base and bed length specs
I am doing reasearch for two major projects. One the body is mostly done and under primer, but waiting frame mods(79 4dr+supercab with short bed{maybe shorter short bed}), the other 4dr bronco, planning stage. My questions is what are wheel bases on various available trucks? And what are the actual bed lenth differances long vs short? This much I think I have determined by going through the yard and checking data plates,
..................4dr short bed wheel base 150",
bed 6' 10.25"? (bed damged),
............Supercab long bed wheelbase 155",
bed 8' 2.25"? (again damaged bed),
.........regular cab long bed wheel base 133",
...........................bronco wheel base 105".
I got a rough bed differance at 16" or 1' 4".
I could narrow this down if I could get the data on a regular cab short bed (we aint got a one). Assuming there where only two bed lenths.
Anything to add?
www.reddogracing.org
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-22-2003, 11:59 PM
Mil1ion is starting off with a positive reputation.
This should help you.
  #3 (permalink)
Old 03-23-2003, 12:10 AM
Bronco Specs
  #4 (permalink)
Old 03-23-2003, 12:43 AM
the bronco pic is great would love to have one of those for the pickups, but it says 104, yet i have wrote down that the data plate on the one i looked at says 105, which i will double check monday. As for the other data sheet pics, i can not make out (even using a progragm to voom in) if all the shortbed lenths(styleside) are the same as far as the fractions go. Also would like to see the whole sheet, where can i get a copy, or good scanned double. thanks fo rthe quick reply and good info.
  #5 (permalink)
Old 03-23-2003, 12:47 AM
I would be intersted to see the approach angle differances in the bronce wersus pick up. I assume the front would be the same as a pick up, but how the rears compare short and longbeds would be intersting to know. The Bronco projct will of course have a bronco rear end mated to a 4dr front, so it doesnt matter as far as the project goes, just curiousity.
  #6 (permalink)
Old 03-23-2003, 03:24 AM
It should be readable now.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
